Old 10-23-2017, 02:01 PM   #41
Tim Ayers
Default Re: Favorite Early V/8 Tool & Why?
Originally Posted by rotorwrench View Post
I like the All Power horse shoe clip puller and the valve assembly wedge knocker to pop them out. If that doesn't work the KD 918 valve guide puller is next. These have helped me get a lot of crusty old flatheads apart with a way lot less trouble. There are others but these are likely the best overall that I have.
Agreed. I got all three of those tools as well. It was interesting to see the rod on the knocker off the head for mine broke at the same spot. Never got around to welding it up. The guide knocker is no joke. It once popped a valve assembly that was stuck like glue out of the block and across the garage.
Old 10-23-2017, 04:32 PM   #42
mercman from oz
mercman from oz's Avatar
Here is a close-up picture of the small engine blocks used to lift the Flathead V8, as posted by Flathead37. Notice the notches on the side, so that they don't move once put into position. This pair of blocks belong to Lawrie.
mercman from oz is online now   Reply With Quote
Old 10-28-2017, 09:19 PM   #43
RalphM
RalphM's Avatar
This would have to be my favorite! I have not used it as much as I enjoying looking at it. A work of art!
File Type: jpg CBC9769B-A9BF-4349-BDA6-023EB8C1BE3A.jpg (62.8 KB, 88 views)
RalphM is offline   Reply With Quote
Old 10-29-2017, 06:45 AM   #44
Tim Ayers
Ralph,
What is it or what does it do?
Old 10-29-2017, 07:48 AM   #45
KiWinUS
KiWinUS's Avatar
Originally Posted by Tim Ayers View Post
Ralph,
Looks like a valve spring pressure checker ? The handle apears to be a torque wrench. If I am correct it is very nice & I have not seen one like this.
Cheers
Tony
Old 10-29-2017, 09:19 AM   #46
Tim Ayers
Cheers
Tony
Ah, yes. I think you are right.
Old 10-29-2017, 10:52 AM   #47
RalphM
RalphM's Avatar
Yes, that is what it is for. The torque wrench must be the older beam style. You set the spring height then pull down on torque wrench while watching needle. There is an audible “click” when spring pressure is reached.
Old 10-29-2017, 01:54 PM   #48
flatford8
flatford8's Avatar
This is handy for turning over an engine. As long as the flywheel and bell housing are on...... Mark
File Type: jpg 15B404C8-3E1F-4474-8FA6-5295A540463F.jpg (33.8 KB, 43 views)
File Type: jpg 92FD9DF2-E1DA-48BD-83B6-935214526AE6.jpg (36.5 KB, 30 views)
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 09-05-2018, 09:28 PM   #49
VeryTangled
VeryTangled's Avatar
Bringing this great thread back up with a tool that I found my buddy JM 35 Sedan using... It's a timber just about as wide as 600x16 tires with a couple of stoppers added, six by six or eight by eight I don't know for sure. Make four of them! Very easy way to get safe access when you're on level solid ground...
Edit to add: I wish we could use these on the show fields because so many cars ride too low for my fat butt to wiggle under!
File Type: jpg 33579944_521901544878843_6119366044952821760_n.jpg (32.5 KB, 39 views)
-Jeff H
Old 09-05-2018, 09:46 PM   #50
Tinker
Tinker's Avatar
I don't have anything special. just my spring spreader, hub puller, and valve fork.
Old 09-06-2018, 04:13 PM   #51
Kube
Super Moderator
Kube's Avatar
Originally Posted by DavidG View Post
The KRW spring shackle stud remover/installer.
My gosh yes! This tool makes this otherwise ugly task a breeze.
Kube is online now   Reply With Quote
Old 09-07-2018, 08:05 AM   #52
Cecil/WV
Cecil/WV's Avatar
My favorite tool is the one I need at the time I am doing the job.
Cecil/WV is offline   Reply With Quote
Old 09-07-2018, 08:23 AM   #53
Tim Ayers
I have these two as well. The wedge knocker literally shot a crusty old guide across the garage after a few good whacks with the weight.
I like the Lee bolt on valve checker. It's just a neat tool to have.
Old 09-07-2018, 11:33 AM   #54
DavidG
DavidG's Avatar
K.R. Wilson BV-121 spring shackle stud remover/replacer makes a tough job easy (well, relatively easy).
Old 09-07-2018, 12:08 PM   #55
Tim Ayers
I wish someone would re-cast these. Seems simple enough. I'd love to have one.
Old 09-07-2018, 11:27 PM   #56
Tinker
Tinker's Avatar
Old 09-08-2018, 10:06 AM   #57
RalphM
RalphM's Avatar
I think these two have become my new favorites!
They make valve removal a snap!
File Type: jpg 36277B17-9737-4B99-AF12-3BD255CA8566.jpg (67.6 KB, 35 views)
