Old 07-26-2018, 12:52 PM   #1
1930artdeco
1930artdeco's Avatar
Default Best way to punch a hole in welting
Hi All,
I am going to install my new floor boards soon but have a question:
1) What is the best way to punch a hole in the welting for the screw?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-26-2018, 12:59 PM   #2
MikeK
MikeK's Avatar
Default Re: Best way to punch a hole in welting
A Roper Whitney punch works if you have one. So does a rotary leather punch. Or stand- alone single size gasket punches against a wood end-grain backing. Or a piece of tubing with a sharpened edge in an electric drill, again against a wood backing.
MikeK is offline   Reply With Quote
Old 07-26-2018, 02:33 PM   #3
davehc
davehc's Avatar
A set of these from HF works pretty good .
Didn't mean to post it so big !
Hollow Punch Set 9 Pc
Pittsburgh®- item#3838
Rated 3.9 out of 5 stars
125 ReviewsWrite a Review
Punch holes with precision ground flutes and cutting edges
Only: $8.99
Compare to $50.99, General 1280ST
Qty:
davehc is offline   Reply With Quote
Old 07-26-2018, 02:59 PM   #4
aermotor
I use an awl or pointed screwdriver, torch heat and it will slide right through with a nice clean hole that won't frazzle around the edges.
John
aermotor is offline   Reply With Quote
Old 07-26-2018, 03:18 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by 1930artdeco View Post
Hi All,
Mike
Forgive my ignorance but are you talking about the floorboards where you put your feet when you drive? What screws go through the welting?
Old 07-26-2018, 03:36 PM   #6
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
Thought floorboard welting was tacked on.
Rusty Homestead Fl is offline   Reply With Quote
Old 07-26-2018, 04:18 PM   #7
aermotor
It is but it wraps around the bottom of the board where the screws go to the sub-frame.
John
Old 07-26-2018, 04:39 PM   #8
1930artdeco
Aermotor, I may try your method as I have both. If it doesn't work then off to HF I go.
Thanks for all of the replies.
Mike
1957 Country Sedan
Old 07-26-2018, 06:45 PM   #9
J Franklin
J Franklin's Avatar
I just cut notches where it interferes with bolts and machine screws, same as fender welt.
Old 07-26-2018, 08:16 PM   #10
larrys40
John
I agree with John . It is easy and deals up the edge of the hole to keep it from unraveling. It works great for frame welting as well. Bigger hole means bigger punch. I use taper line up punches and heat them with my trigger propane torch
Larry Shepard
larrys40 is offline   Reply With Quote
Old 07-26-2018, 08:38 PM   #11
Doug_Knutson
I just use an official hole punch and a block of aluminum .. magic
Doug_Knutson is offline   Reply With Quote
Old 07-27-2018, 02:27 AM   #12
pooch
pooch's Avatar
I melt the hole thru with a soldering iron.
pooch is offline   Reply With Quote
Old 07-27-2018, 06:03 AM   #13
aermotor
Larry Shepard
Forgot to mention that using an old hunting knife the same way is good for cutting to length. Be sure to use an unwanted knife as the temper will soon be gone.
John
Old 07-27-2018, 07:26 AM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
[B]DaveH,
It's OK, if you post BIG, many don't know how to do it!
My Dog taught me how to make letters, bigger than a HOUSE.
Bill & Dog
"THE ASSISTANT GURU OF STUFF"
Old 07-27-2018, 09:08 AM   #15
Mike V. Florida
It is tacked and there are no screws on the removable floorboards.
https://www.fordbarn.com/forum/showthread.php?t=97670
https://www.fordbarn.com/forum/showthread.php?t=117478
Old 07-27-2018, 12:38 PM   #16
Randy in ca
Randy in ca's Avatar
Originally Posted by Mike V. Florida View Post
I think he's referring to the screws that hold the boards in place. Some of the holes thru the welting for these screws are shown in the pictures in the theads you provided.
Randy in ca is offline   Reply With Quote
Old 07-27-2018, 05:23 PM   #17
[email protected]
Use different sized shell casings and a hammer. Makes a neat hole.
Hodbilll@Yahoo.com is offline   Reply With Quote
Old 07-27-2018, 07:16 PM   #18
23hack
Do you mean with a live round ? How many rounds does it take ?
23hack is offline   Reply With Quote
Old 07-28-2018, 07:09 AM   #19
deuce5wndw
deuce5wndw's Avatar
Larry Shepard
This works really well when installing new carpet also. Seat belt bolt holes etc. No more frazzled carpet! Dale
deuce5wndw is offline   Reply With Quote
Old 07-28-2018, 09:21 AM   #20
MikeK
MikeK's Avatar
There's a bit of talk on this thread about using heat and melting the hole, with the benefit of no fraying edges.
Linen, cotton, silk, wool, and felt(an unwoven wool product) are all natural products that will NOT melt. Yes, they will burn, but that will not seal or fuse the edges. Only later synthetics like nylon, polyester, rayon will actually melt.
I have yet to encounter any anti-squeak material used in, or presently sold for Model A's that actually melts. It burns, yes. But burning does not fuse the edges.
Burning also leaves a fine carbon matrix on the fiber terminations that is hygroscopic. The last thing I want around a fastener hole is material that attracts and holds water.
