Old 06-25-2018, 11:01 PM   #1
Fourdy
Fourdy's Avatar
Default Break-in oil & Ross pistons
I have been advised that I should use a break-in oil such as Gibs break-in oil for my rebuilt blower 276 flatty. I can’t seem to find whether or not it is indeed the best to use for break-in or any different than using VR-1 for both initial and after break-in.
I could also use some advice for the Ross piston with metric rings. Any special tricks to get them installed properly? I have read and studied the instruction sheets.
Any advice would be appreciated. Thanks
Fourdy
Fourdy is offline   Reply With Quote
Old 06-26-2018, 12:14 PM   #2
Brian
Brian's Avatar
Default Re: Break-in oil & Ross pistons
It is my understanding that running in oil has no friction modifying additives; it is plain mineral oil, designed to allow the rings to quickly bed in. I always change that oil after the first 50 odd miles, thereafter run the oil of your choice.
My experience with those metric rings is that the top rings cannot be filed with a regular file should you need to open up the gap. You'll need a special ring gapping thingee with an abrasive disc that you rotate against the end[s] of ring
Old 06-26-2018, 12:39 PM   #3
flatjack9
flatjack9's Avatar
I just installed a set in an engine I am building. I did use ring gap grinder. No problems and the installation was straight forward. I will say I did notice less drag when turning the engine over. I have always used conventional oil right from startup and have never had anyone complain that the rings did not seat.
Old 06-26-2018, 01:28 PM   #4
Fourdy
Fourdy's Avatar
Brian - what oil do you use?
Flatjack - I do have a gap grinder.
Thnx
Fourdy
Old 06-26-2018, 10:49 PM   #5
Brian
Brian's Avatar
I'm down under and so probably have different oil suppliers than you guys. The running in oil is marketed by Penrite [Ozzie company], and is called running in oil.
The 'thingee' I referred to is a gap grinder.
Old 05-01-2024, 09:08 AM   #6
jake197000
new cars dont use break in oil and they work just fine.use the oil your going to use and run it like you stole it
jake197000 is offline   Reply With Quote
Old 05-01-2024, 09:38 AM   #7
glennpm
glennpm's Avatar
On first start, keep RPMs over 2,ooo RPM and then drive it!
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
glennpm is online now   Reply With Quote
Old 05-01-2024, 10:01 AM   #8
Ol' Ron
Ol' Ron's Avatar
Ross makes a very good racing piston, that is not suited for "street use". However the only alternative would be Egge, IF they made then in the right size. Unfortunately we\re at the mercy of the provider.
Gramps
Old 05-01-2024, 10:56 AM   #9
itslow
itslow's Avatar
What about their Flathead pistons is not suitable for street use?
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 05-02-2024, 01:12 PM   #10
Pete
Gramps
Ross makes street pistons also.
A little known fact, back in the Forgedtrue piston days, they also made street pistons.
Old 05-02-2024, 10:17 PM   #11
Ol' Ron
Ol' Ron's Avatar
Learn sumpin every day/ Thanks PeteI build an engine back in the 90's that was 3/8 x3/8 296ci with Hyper utecnic pistons/ It was peplaced by a 294 Blown engine back in 2012 I offere to fresh the 296,but the owner said it didn't use a drop of oil and still ran great. Wish I had it .
Gramps
Old 05-02-2024, 11:38 PM   #12
stingywrap
New cars function perfectly without the need for break-in oil.Use the oil you intend to use and operate it as though it were your own.
stingywrap is offline   Reply With Quote
