Old 04-21-2018, 01:56 PM   #21
midgetracer
midgetracer's Avatar
Default Re: Rear Float-a-Motor Mount Install Issue
Antique and Rosemead are indications of manufacture by Jim Gordon at Antique Auto Parts in Rosemead California. He is located on Garvey Avenue. Jim seems to be a great guy. Hi father in law was Gene Schott (ol Flathead) I believe.
midgetracer is offline   Reply With Quote
Old 04-21-2018, 02:34 PM   #22
KansasRick
This thread was started Jan. 1, 2018. Surely there has been some resolution. Anyone know?
KansasRick is offline   Reply With Quote
Old 04-22-2018, 06:09 AM   #23
marty in Ohio
marty in Ohio's Avatar
Daveymc29 and midgetracer,
Thanks to both of you for the info. I took my FAM's apart yesterday and found the rubber donuts. I'm going to Snyder's tomorrow to get the replacements. As far as resolution to this post, I learned a lot and am going to fix mine. I guess everyone gets out of these posts what they want.
Marty
marty in Ohio is offline   Reply With Quote
Old 04-22-2018, 07:12 AM   #24
Growley bear
Marty
The information on Ford Barn seems endless and is also priceless. Most of the info here is based on experience; that is the best kind.
Growley bear is offline   Reply With Quote
Old 04-24-2018, 02:54 PM   #25
arvon
I just purchased a car with fam it has a bad vibration. Can you see the rubber plate on the outside of the frame after it is installed? I think it may have been left out.
arvon is offline   Reply With Quote
Old 04-25-2018, 09:39 AM   #26
katy
katy's Avatar
Yes you can.
Old 06-13-2018, 02:48 PM   #27
Lanceh5
I am installing the engine after installing a gasket between the rear of the block and the flywheel cover, fixing a big oil leak. The FAM that I am installing on a 1930 Coupe came from Mac's Antique Auto parts and took me many hours to remove the old and install the new. The motor now is too high and the throttle mechanism is touching the firewall. I may shave off some of the rubber disk to reduce the the height.
Lanceh5 is offline   Reply With Quote
Old 06-13-2018, 04:30 PM   #28
denniskliesen
denniskliesen's Avatar
Check to make sure they are installed properly. There is TOP molded in the part that bolts to the flywheel housing.
denniskliesen is offline   Reply With Quote
Old 06-13-2018, 08:17 PM   #29
kd4lok
kd4lok's Avatar
Installed FAM’s in my 31 Coupe about 3 years ago. Likely from Snyder’s. No problems in my case.
Bob
kd4lok is offline   Reply With Quote
Old 06-13-2018, 11:38 PM   #30
duke36
Antique in Rosemead was one of the earlier vendors along with JC whitney before others hit the scene. They had a bunch of original parts available also, back in the '70's. Imo, the new FAMS made of steel or iron are less prone to fatigue than the alum. The donuts need to be replaced when hard,and adjusted as per many posts on the BARN which can take many tries to suit ones engine. Firm but not rock hard and no donut bulge. The crossmember support is essential to keep the drive line aligned, even on cars with F150 trannies which needs a special yoke at the tranny support..
Old 06-14-2018, 08:02 AM   #31
Railcarmover
Don't accept a misaligned motor mount issue on account that you dont hand crank the car.If the crank bearing (crank hole) doesnt align with the crankshaft your drive shaft is out of alignment as well.The ujoint will accommodate the misalignment,with a potential cost of increased vibration and wear.
Railcarmover is offline   Reply With Quote
Old 06-14-2018, 09:08 AM   #32
katy
katy's Avatar
In my case the crank bearing misalignment was caused by the front motor mount.
Old 06-14-2018, 09:48 AM   #33
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I "think" that some difficulty in installing them is to be expected. These VERY FLEXIBLE Frames have been twisted & flexed, over UNEVEN Terrain, for MANY YEARS!!! The '32 frame was designed MORE RIGID, to overcome this problem!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-14-2018, 09:55 AM   #34
fredski53
fredski53's Avatar
I had the same problem wit the ones I got from MACS. Drilled new holes.
fredski53 is offline   Reply With Quote
