Old 05-16-2018, 03:37 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: adding std bypass oil filter
All the supply and return ports are in the block.
The only major difference is how the canister assy. is mounted to the head.
Early ( prior to 1950 ) 8BA's mounted using head bolts. The later ones had dedicated bosses cast into the heads.
The oil return hole is tapped into the side of the block, above the pan rail.
