Old 05-08-2018, 09:34 AM   #3
Kube
Super Moderator
Kube's Avatar
Default Re: JD Corn Head Grease Uses ?
Originally Posted by V8COOPMAN View Post
Those are about the only two places that you'd want to use it on an old Ford....clamshell and steering box. DD
Yes sir! These are the two places I use it. I have made a plug with a grease fitting for the steering gear box. Utilizing it, I am confident the box is 100% full. Then I replace it with a stock plug.
I also use the grease in the torque tube center bearing...
