Old 03-10-2018, 02:30 PM   #1
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: lutch Chatter
Al,
Try taking off Gently in second, for a month. That cured Minervas' chatter.
Let me know if that helps, if so, I'll explain WHY it helped.
Bill Smooth
"THE ASSISTANT GURU OF STUFF"
Old 03-10-2018, 02:46 PM   #2
hardtimes
hardtimes's Avatar
Originally Posted by BILL WILLIAMSON View Post
Al,
Bill Smooth
Hey Smooth,
Back when, we used to use an apple tree trunk to achieve same results..only quicker. Burning viscous junk and rust off of clutch surfaces is a bandage fix, till you can find enough time/money to do it right sometime. Rear main oil leaks were/are common (cause for chatter) and may need to be fixed when in there also.
Old 03-14-2018, 07:45 PM   #3
BillEbob
BillEbob's Avatar
Wink Re: lutch Chatter
Al,
Bill Smooth
Bill,
I'm STILL waiting for you to explain to me WHY❗
Other Bill
BillEbob is offline   Reply With Quote
