Old 02-22-2018, 11:19 AM   #1
Leatherback 57
Leatherback 57's Avatar
Default Re: Wishbone ball
My front end has all been rebuilt. My ball looks to be in good shape but has rubber ball cover installed and was worn out. Is there spec diameter for original ball? If good I'll go back to original. I set toe in to 1/16. Was at 3/8 toe out!!!
Leatherback 57 is offline   Reply With Quote
Old 02-22-2018, 11:53 AM   #2
WHN
A lot of guys do not like the rubber ball. Having said that. If just replacing the rubber ball will get you back to where you want to be? That sounds like the best thing to do. Will most likely last for a good number of years.
If it isn’t broken, don’t fix it.
