Old 01-25-2018, 09:10 PM   #1
gnolnor
gnolnor's Avatar
Default Need water pump rebuilt or to purchase
Attachment 348299
Attachment 348300
Attachment 348301
Attachment 348302
Barners,
My neighbor across the street has a '54 F-500, with a Y block 292.
It is a flat bed with a winch. Nice truck. He is new to the hobby. He
has a bad water pump and has had no success in getting a replacement.
Any information on a vendor would be appreciated. Rebuild what we have
or purchase a rebuilt one. Thank you for your reply, gnolnor
gnolnor is offline   Reply With Quote
Old 01-25-2018, 09:31 PM   #2
miker98038
miker98038's Avatar
Default Re: Need water pump rebuilt or to purchase
I can’t get the attachments to open. But if it’s a 54, it’s a 239 or (unlikely) a 256 Merc motor. They used a smaller water pump that’s hard to come by. If it actually has a 272-292, that larger pump is readily available. Look at the casting numbers, and try reposting some pictures. A lot of early motors where replaced by later motors.
miker98038 is offline   Reply With Quote
Old 01-25-2018, 09:35 PM   #3
scrapiron
The original motor in a '54 would have been a 239 or 256, not a 292. '54 was a first year "Y", and many differences from '55 on.
Find a parts store with old guys and books,,,,
beat me to it,,,,,,,,,
scrapiron is offline   Reply With Quote
Old 01-25-2018, 10:17 PM   #4
paul2748
paul2748's Avatar
Check the centering pin on the old pump. If it is the larger one it is a truck pump and if a 292 look for a pump for a 64 truck. If it has the smaller pin then it is a car pump and these should be available from the old car parts suppliers.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-25-2018, 10:56 PM   #5
dmsfrr
dmsfrr's Avatar
In an F-500 from '54 is there a possibility it's a Lincoln y-block engine... ???
If so it should be easily ID'd by a double ridge in the valve covers next to the hold-down nuts.
(see images at this link)
http://ford-y-block.com/lincoln.htm
Old 01-26-2018, 08:28 AM   #6
BW
Try www.flowkoolerwaterpumps.com and I think they can rebuild your old one
BW is offline   Reply With Quote
Old 01-26-2018, 10:54 AM   #7
gnolnor
gnolnor's Avatar
Barners, Thank you for the info on all replies. I will print your posts and
forward them to my neighbor. Gnolnor
Old 01-27-2018, 10:32 AM   #8
willowbilly3
About a year ago I needed a pump for my 59 pickup. The 3/4" shaft were unobtanium. I finally found a couple places that still had NOS and paid through the teeth for one. I must have found a dozen listings for a reman, mostly A1 Cardone but all out of stock, even A1's website.
willowbilly3 is offline   Reply With Quote
Old 01-27-2018, 03:26 PM   #9
Alaska Jim
Alaska Jim's Avatar
Try Green Sales. they may or may not have one, but they deal in N.O.S. Ford Parts
Alaska Jim is offline   Reply With Quote
Old 01-30-2018, 11:11 PM   #10
abe54
abe54's Avatar
The water pump will have to be sent away to be rebuilt, unless you rebuild it yourself. I had to do the same for my 54 F100 with the 239 Yblock. Since the 55 and 56 water pumps were different and the 54 was a one year pump, rebuilt ones are not out there.
Show us some pictures of this 54 F500.
Abe
54 F100
Bought from Grandpa in 1977
55 F350
Bought in April 2016
abe54 is offline   Reply With Quote
