I installed new valves and ran adjusters all the way down. I have at least .050 clearance except 2 valves that I had to grind stems.Adjusted all to .015. Couple valves only have max .025 left on adjusters before they bottom out.Should I grind those stems to allow more adjust room or am I ok?
That's .010 more left.
If they ever need to be adjusted more than the .010" there is something wrong.
Something is not right here, if I am interpreting your post correctly. May I ask what set of instructions you are following for setting your valves, and if you are using modern valves and/or a modified cam?
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole.
All my old valves had the stems cut down. Before doing valve job, I adjusted Al lifters down to bottom. Ground 3 angle seats and installed new valves and lapped in. I use the plus 9 method for valve adjust. Clearance before adjusting valves as noted. After adjusting all valves to.015 a couple lifters only have .010 left before they bottom out. The stems I ground allowed for. 050 extra for further adjustment if needed. Usually clearance gets larger with wear. Just wandered if I should give the2 valves a stem grind or let go.
I've adjusted mine to .012 intakes and .014 exhaust
#8 | |
On overhead valves, clearances can get larger with wear: pushrod tips, rocker arm faces and pivot points all wear. |
#9 | |
I have set mine on sixteen thousants , Intake and exhaust . More time on the seat better cools the valves and reduces the chance of burning valves. Snyders recommended this setting , years ago and it has worked good for me . My reground Winfield super street 3/4 race cams use the same sixteen thousants gap .
I used the 13 and 15 that is in the Les Andrews book
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
#12 | |
| Thread Tools | |
| Display Modes | |
