Old 11-26-2017, 09:34 PM   #4
cmbrucew
cmbrucew's Avatar
Default Re: dial indicator adaptor
Originally Posted by tubman View Post
You might try an old snowmobiler's trick. Feed enough rope down through the spark plug hole to act as a piston stop. Turn the crankshaft both ways until it stops turning. Halfway between is TDC. You would have to be kinda careful not to vary the amount of rope in the cylinder and rock it back and forth several times to account for the compress-ability of the rope, but I bet it'd be close. I think a dial indicator extension would be tough.
I've done this a lot on snowmobiles, but admit I've never tried it on a flathead Ford.
Bruce, could you explain how that dial indicator set up would work?
You are correct, my bad. You know Chrysler industrial engines had a hole thru the head for that very purpose. Just remove the pipe plug and drop in a welding rod or whatever.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
