Old 09-23-2017, 03:03 PM   #1
mll1446
Default 1947 mercury brake question
i have replaced brake shoes , drums have been cut, replaced master cylinder and junction block and wheel cylinders when i have car up on all four wheels spins and brakes work fine
however when i drive it rear brakes are hot and seem to drag ? any suggestions on problem and or fix
mll1446 is offline   Reply With Quote
Old 09-23-2017, 03:39 PM   #2
DD931
DD931's Avatar
Default Re: 1947 mercury brake question
Be sure that there is play in the master cylinder rod to insure that the piston comes all the way back to allow return of fluid from wheel cylinders. You may still have pressure on the rears even when your foot is off the pedal.
DD931 is offline   Reply With Quote
Old 09-23-2017, 05:37 PM   #3
Karl Wolf
Karl Wolf's Avatar
How are the return springs on the brake cables?
They are on the inside, pull the drums to get to them.
You may be able to assess their condition by pulling on one at a time,
right at the cable entry to the drum. (It may help to back off the adjusters)
This could be the cause of dragging brakes.
Karl
Karl Wolf is offline   Reply With Quote
Old 09-23-2017, 05:44 PM   #4
5851a
When younger I would just replace the brake shoes, now I look at all of the friction points on the backing plates making sure there are no grooves worn in them and lube them with Brake Lube. I also get the new return springs that I didn't used to think were important.
5851a is offline   Reply With Quote
Old 09-23-2017, 08:14 PM   #5
mll1446
Would axle or differential have any effect on the heating up and braces locking up?
Old 09-23-2017, 08:36 PM   #6
mll1446
Old 10-01-2017, 07:52 AM   #7
5851a
Have you replaced the brake hoses? They can deteriorate internally and turn into one way check valves that will hold the brakes on.
