Old 09-16-2017, 02:40 PM   #1
Bill S
Default drill bit
I have been practicing sharping drill bits by hand. No luck holes are not round. So I was thinking about getting a Drill Doctor. They have the one that does only 118 degree angle and one that does 118 and 135 degrees. How often do you think a bit with an 135 degree would be needed? The cost between the two is about $35.00 more for the one that you can put a 135 degree angle on the bit. I do some projects using bed frames that seem like a harder seel than mild steel.
Thanks
Bill S is offline   Reply With Quote
Old 09-16-2017, 02:46 PM   #2
Ronnie
Ronnie's Avatar
Default Re: drill bit
https://www.drilldoctor.com/faq
R
Ronnie is offline   Reply With Quote
Old 09-16-2017, 02:55 PM   #3
35ragtop
35ragtop's Avatar
I bought the two angle version several years ago and have never regretted it. Now my bits are sharp and you get very quick at setting up for a sharpen.
I could never master the free hand method.
Dave
35ragtop is offline   Reply With Quote
Old 09-16-2017, 03:00 PM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I have the single angle and have had for years , couldn't be without it....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-16-2017, 04:05 PM   #5
RKS.PA
RKS.PA's Avatar
I have the two angle one as well.....I've collected each type of angled bits over the years, and this set up let's sharpen each to its original finish. Like most things for me, there was a learning curve until I got it right, particularly the split point feature!!
Dick.
RKS.PA is offline   Reply With Quote
Old 09-16-2017, 04:27 PM   #6
mfagan
mfagan's Avatar
The two angle Drill Doctor works well , easy to use.
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 09-16-2017, 04:37 PM   #7
TagMan
Two angle one I bought gets a lot of use for both wood & metal bits.
TagMan is offline   Reply With Quote
Old 09-16-2017, 04:40 PM   #8
19Fordy
19Fordy's Avatar
Bill, Don't know what you're making with the old bed frames but, be careful. Read about what bed frames are made of here.
https://www.google.com/search?q=what...=1600&bih=1117
19Fordy is online now   Reply With Quote
Old 09-16-2017, 05:26 PM   #9
deuce_roadster
deuce_roadster's Avatar
A machinist would say no drilled hole is round until it has been reamed to size.
Drill Dr. works pretty well on bits 1/4 and larger.
Old 09-16-2017, 05:48 PM   #10
rotorwrench
rotorwrench's Avatar
I use the Uni-Bits (single flute type)to get a rounder hole and to make small holes larger. I used to think that they were a gimmick till I used one. There is nothing else that can drill through plexiglass without cracking it. They will drill well through soft metals too. They're expensive but they last a long time. You need a mill to drill very accurate holes but still should ream them for close tolerance.
I use my Drill Doctor for large bits but I have an 8-inch disk sander wheel that I use to do the smaller ones since its just quicker to do them by hand. I use a small green wheel grinder for my old lathe bits but I mostly just use the carbide tip type now.
Old 09-16-2017, 06:52 PM   #11
Bill S
Thanks everyone you have been a great help.
Old 09-16-2017, 07:33 PM   #12
Kube
Super Moderator
Kube's Avatar
Funny as heck.
Reaming will get a hole fairly round. Good enough for a machinist for certain.
A tool maker knows that holes are not round until they have been ground.
Old 09-16-2017, 07:52 PM   #13
34fordy
34fordy's Avatar
Originally Posted by Kube View Post
Funny as heck.
As "beauty is in the eye of the beholder" so goes the round hole. It depends on what your tolerance is. I would venture to say that there is no man made hole that is round. Mighty close with the instruments that we measure with, but still not perfect!
34fordy is offline   Reply With Quote
Old 09-16-2017, 08:20 PM   #14
1948F-1Pickup
1948F-1Pickup's Avatar
No Drill Dr here but I'd like one.
A three flute drill is probably closest for a quickly bored hole.
(aluminum or cast iron) Very much a perfect circle.
Reamed holes are just ok as far as being perfectly round and exact.
Honed would be more accurate and water jet is also pretty good.
1948F-1Pickup is offline   Reply With Quote
Old 09-16-2017, 09:28 PM   #15
DD931
DD931's Avatar
Let me guess, Kube. Were you a tool and die maker?
DD931 is offline   Reply With Quote
Old 09-16-2017, 09:40 PM   #16
VeryTangled
VeryTangled's Avatar
https://www.fordbarn.com/forum/member.php?u=69
-Jeff H
Old 09-16-2017, 10:40 PM   #17
ford35lh
But, you don't have to be a tool and die maker to operate a jig grinder.
ford35lh is offline   Reply With Quote
Old 09-16-2017, 10:53 PM   #18
38bill
38bill's Avatar
I have the 750 and love it. Basically paid for itself with just a few sharpening's of my 3/4" drill bit.
38bill is offline   Reply With Quote
Old 09-17-2017, 12:27 AM   #19
Bubsyouruncle
I would guess it goes back to what you want the hole to do.
If you are looking for clearance to hold two parts together, you could use an ice pick and a hammer. Grin.
A little tighter than that and good commercial drill bits will work.
After that, you are into reaming and boring and honing. But, hey, are we building tooling or just clipping stuff together?
On the subject of drill point sharpening:
Back in the late 1950s I was employed, as a high-school student during the summer, by Skil Corperation, when they were located at Elston and Cicero in Chicago. My project was to investigate, by activity, drill-point angles and how they effected power consumption. Skil was looking at battery tools at the time and wanted to know.
1957. Or 8. Don't remember. Been a while. Grin.
Quite by accident I managed to produce a drill-point that used less than 50% of other points.
Unfortunately, for the rest of time, I was unable to reproduce it. The original, for several weeks, always performed. The duplicates, produced on the same tool grinder, by the original tool maker, never did.
Point - Magic? Accident? Unknown factors?
Bubsyouruncle is offline   Reply With Quote
Old 09-17-2017, 02:18 AM   #20
tiger.1000
Bill,
With some practice you WILL get the hang of sharpening drill bits by hand. The BIG mistake people make is treating the bit like a pencil going into a pencil sharpener and turning it through 360 degrees.
I guess that a search on YOU TUBE will show you how it's done ?
tiger.1000 is offline   Reply With Quote
