Old 08-31-2017, 04:51 PM   #1
jimTN
Default C91A6050 Canadian heads
I have a C91A 6050 and C91A 6049 set of alum. heads. The appear to be the real thing, not USA made racing HC heads. Are the Canadian heads higher compression or 6.5 to 1.
Old 08-31-2017, 04:53 PM   #2
42merc
42merc's Avatar
Default Re: C91A6050 Canadian heads
Not high compression.
Standard low comp Ford.
42merc is offline   Reply With Quote
Old 08-31-2017, 07:26 PM   #3
Kube
Super Moderator
Kube's Avatar
High compression heads had "AS" in the prefix.
Old 08-31-2017, 08:03 PM   #4
JSeery
JSeery's Avatar
Kube, are those what are sometimes referred to as "Denver" heads?
Old 09-01-2017, 07:34 AM   #5
scooder
Yes AS heads were commonly referred to as Denver heads.
Martin.
scooder is offline   Reply With Quote
Old 09-01-2017, 03:51 PM   #6
topfuel724
topfuel724's Avatar
Were the "AS" heads made in aluminum and steel?
topfuel724 is offline   Reply With Quote
Old 09-01-2017, 04:06 PM   #7
Bruce Lancaster
AS heads are iron. The C in the PN designates Canadian manufacture...Some Canadian aluminum heads had slightly higher than irn CR's, probably just enough to compensate for the slight power loss. There is a Canadian service bulletin page listing CC's An CR ratings for nearly all USA and Canadian heads from about '32-49
Old 09-01-2017, 04:12 PM   #8
Kube
Super Moderator
Kube's Avatar
Some AS heads were aluminium.
I have a set of 99AS heads, NOS, that are aluminum. According to the authentic documents that remain with this vehicle, they were were ordered (originally) to be installed on my '40 convertible (factory Merc. engine). It took me a LONG time to locate that set.
Old 09-02-2017, 10:45 AM   #9
Milt/Las Vegas
Milt/Las Vegas's Avatar
I have a 40 convertible that has aluminum heads made in Canada with C7RA 6050 B.I was a ford partsman in the 60s and early 70s and understood that was an engineering number,C for decade 60 and 7 was the 7th year and 6049/6050 was the basic number cylinder heads.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
