Old 08-18-2017, 01:54 PM   #1
elwood
elwood's Avatar
Default What carbs are these ?
Hey guys, I bought a old race car, and these carbs are on it.
They look like 94s to me, except they have a power valve on the outside, I took them apart to clean them, turns out they have a power valve on the inside and outside, and they are bigger than 94s ..
elwood is offline   Reply With Quote
Old 08-18-2017, 02:05 PM   #2
Bob C
Default Re: What carbs are these ?
I think they are EC from about 1954. The first picture looks like the
ultra rare side draft version.
Bob
Old 08-18-2017, 02:11 PM   #3
JSeery
JSeery's Avatar
Little easier to see rotated. Interesting intake as well.
Old 08-18-2017, 02:31 PM   #4
38bill
38bill's Avatar
Holly carbs off a early Ford "Y" block??????
Intake looks like a Eddie Meyer's.
38bill is offline   Reply With Quote
Old 08-18-2017, 02:35 PM   #5
Bruce Lancaster
There are a bunch of variants of these carbs...the Model # is on driver's side of bowl, stuff like EC-6, and will ID the application. The outside valve is an extra kink in the vacuum system for the Holly distributor.
Old 08-18-2017, 08:10 PM   #6
paul2748
paul2748's Avatar
What are the numbers on the side of the carb?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-18-2017, 08:18 PM   #7
tubman
tubman's Avatar
Holley 2100's or 2110's . Used on early "Y" blocks. Those aren't power valves. I believe they are called "Spark Control Valves". They look a lot like power valves, but are NOT interchangeable. If you took the carb apart, you'd find a regular power valve where it's supposed to be.
Old 08-18-2017, 08:46 PM   #8
VeryTangled
VeryTangled's Avatar
Hi Everyone. I'm not usually a lover of two-carb setups, but THAT rig is flathead porn IMHO!
-Jeff H
Old 08-19-2017, 02:14 AM   #9
Alaska Jim
Alaska Jim's Avatar
look like EBU carbs off early Y blocks. like what was stated before the valve on the out side is some sort of spark control valve.
Alaska Jim is offline   Reply With Quote
Old 08-19-2017, 10:25 AM   #10
scicala
scicala's Avatar
If your carbs have the larger throttle bores that match the gasket in your picture with the larger holes, then you have the 1956 pass car (272 Y-Block) ECG6 Holley model 2110 carbs. It's possible they are ECG5' also (for '55 model year 272 Y-Blocks). Both have the larger 1 1/16" venturi's too. Highest air flow carb of this style that was factory installed on Ford cars because of the larger than flathead engine.
Sal
scicala is offline   Reply With Quote
Old 08-19-2017, 12:06 PM   #11
elwood
elwood's Avatar
Thank you all very much for the help.
They are ECG6 carbs ...
I thought they where some sort of 94s lol
