Old 08-06-2017, 07:00 PM   #1
willowbilly3
Default Re: Electric fan thermostat install
I have mine in the thermostat housing, set to come on ten degrees after the t-stat opens. 180 degree thermostat, 190 degree Spal fan stat. Fan seldom runs except real hot weather and slow driving, never gets over 205. I have a manual over ride switch but never use it
willowbilly3 is offline   Reply With Quote
Old 08-06-2017, 10:18 PM   #2
expavr
expavr's Avatar
Since you're in the process of setting the system up, I would definitely recommend adding a manual switch in case of failure. The black box that controls the fan in my street rod failed while on a long cruise. Fortunately the fan was wired into the A/C system so I was able to get back home.
expavr is offline   Reply With Quote
