Old 07-12-2017, 01:52 AM   #1
pooch
pooch's Avatar
Default Head stud washers.
My engine came wuth no washers.
I think I have read they should have and should be hardened.
I guess to stop the nut points diigging and false torque readings?
Is this correct for cast iron heads,?.
Not sure where I can get hardened washers from, maybe heat some soft ones and dunk them in oil?
pooch is offline   Reply With Quote
Old 07-12-2017, 01:58 AM   #2
tubman
tubman's Avatar
Default Re: Head stud washers.
I don't know about studs, but I got my hardened washers for my 8BA with headbolts from "GOSFAST" on here. They were perfect. I have to believe he has something similar for studs.
Old 07-12-2017, 02:02 AM   #3
Brian
Brian's Avatar
Only used with aluminum heads, not on cast iron
Old 07-12-2017, 02:05 AM   #4
flatheadmurre
flatheadmurre's Avatar
From factory there where no washers on either studs or bolts.
The nuts should be shamfered a bit to help from digging into the heads.
Old 07-12-2017, 02:11 AM   #5
hardtimes
hardtimes's Avatar
Hey pooch,
You can use hard washers on cast iron heads, but I do not know of any Ford engine that came stock with them.
Hard washers are prudent to use with alum heads and other parts, as the hard nuts will do damage to alum when torqued.
Old 07-12-2017, 03:40 AM   #6
pooch
pooch's Avatar
OK thanks all, I assumed there should be washers, but if not ... will let it be,
Light chamfer sounds good to me to get more correct torque reading.
Old 07-12-2017, 05:45 AM   #7
GOSFAST
GOSFAST's Avatar
Correct, the washers we use work well with either bolts or studs, we've been using them for years now on the SBC 100% stock-appearing builds. They have a very slight chamfer to clear the small radius under the head bolts, can go either way when using studs.
They are almost not noticeable when installed (see photo below).
Thanks, Gary in N.Y.
P.S. It is much better to use them between the fasteners and the castings, they really help save the bolt/nut surfaces. Here's a couple shots of some bolts/washers for the Flatheads.
GOSFAST is offline   Reply With Quote
Old 07-12-2017, 06:22 AM   #8
Ol' Ron
Ol' Ron's Avatar
Never use studs, Harden washers can be had at most auto supply stores as #8 washers, for alum heads.
Old 07-12-2017, 06:57 AM   #9
JSeery
JSeery's Avatar
Also Pooch, if you decide to use washers I wouldn't attempt to harden them myself. The ability to harden a metal depends on the material it is made from and most washers are not the correct composition.
Old 07-12-2017, 09:36 AM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
I've never used bolts in any of the FH engines that I have built or had built. My personal preference has always been to use studs. When I removed the original aluminum 21 stud heads from my avatar 35 fordor sedan and replaced them with cast iron heads, I still used the original hardened washers because all the studs were just a tad bit too long w/o the washers. Plus, I believe the hardened washers do offer some advantages in achieving the correct torque on head nuts.
John
Old 07-12-2017, 05:09 PM   #11
pooch
pooch's Avatar
Same here, I am always anxious doing the last torquing on a 70 year old cast iron thread .
Much prefer studs.
I used studs in the exhaust manifold holes of my 21 studder for same reason.
Old 07-12-2017, 08:30 PM   #12
edhd58
edhd58's Avatar
My 42 originally had what looked like brass nuts and no washers. I replaced the nuts with what said was cadmium plated nuts, I assume steel.
edhd58 is offline   Reply With Quote
Old 07-12-2017, 09:03 PM   #13
harold04kurtis
Gofast,
Do you have washers for ford v-8-60?
Thanks Harold
harold04kurtis is offline   Reply With Quote
Old 07-13-2017, 06:03 AM   #14
GOSFAST
GOSFAST's Avatar
Originally Posted by harold04kurtis View Post
Gofast,
Thanks Harold
Hi Harold, I have similar washers for 1/4", 5/16", 3/8", (7/16" pictured), and 1/2".
P.S. Assuming the "60" also uses 7/16" head bolt fasteners, the washers in the photo above are the correct ones. I believe there are only 34 (total) required though??
Old 07-13-2017, 06:46 AM   #15
JM 35 Sedan
Not always good to ASSUME Gary , the 60 hp, 17 stud FH engines, use 9/16" hex head nuts with 3/8" - 24 threads for head fasteners.
John
Old 07-13-2017, 06:53 AM   #16
GOSFAST
GOSFAST's Avatar
Hi John, you're absolutely correct, not always good to "assume" anything.
P.S. That's why I listed all the available size washers I keep around. I can't recall ever assembling a "60", have done the machining for a friend on a few many years ago, but never actually got to assemble one.
