Old 06-22-2017, 08:45 PM   #21
hotrodjay
Default Re: 21 stud main bearing help and questions
37-41 lower rear main seal out of the package.
hotrodjay is offline   Reply With Quote
Old 06-22-2017, 08:48 PM   #22
hotrodjay
Side view of the lower rear main slinger seal for 37-41 flathead.
Old 06-22-2017, 08:49 PM   #23
hotrodjay
Ok so I figured out how to posts pictures finally...my error. Here they are...what do you y'all think?
Old 06-22-2017, 08:52 PM   #24
hotrodjay
I did...lol, thanks for your patience.
Old 06-22-2017, 08:53 PM   #25
hotrodjay
What do I have here?...lol
Old 06-22-2017, 08:54 PM   #26
hotrodjay
Late 36 early 37? Does my rear main cap differ from a 37? Do I have a 36 cap on my 37?
Old 06-22-2017, 09:02 PM   #27
hotrodjay
While y'all are trying to help me I figured I'd brows some other posts and see if I can help someone else to return the favor😉
Old 06-23-2017, 12:06 AM   #28
flatheadmurre
flatheadmurre's Avatar
A little suprised no one mentioned you are missing a piece of pipe on the cap...
The idee is to get the oilreturn below the oillevel of the engine to prevent blowby going out the rear mainseal.
Looks like you have a mix of a single and double singer seals.
Old 06-23-2017, 01:27 AM   #29
hotrodjay
I know about the drain pipe, ford canceled that in early 35 due ti the crank case ventilation system. Question is does this particular main cap have a lower seal or not? If my engine is a late 36/early 37...maybe there is no seal. Is there a seal for this cap or not? Ready to install the pan but need a definite answer. Again...there was no drain pipe from 37-41. None from 41-48. Does my main cap fit a slinger seal or not? Maybe my 37 is an earlier model where a lower slinger seal didn't exist like the 36. Guess I have an early 37...36 had no seal at the main cap. I'll put it back together the way it was.
Old 06-23-2017, 01:29 AM   #30
Brian
Brian's Avatar
Your rear cap certainly resembles the type found on a 36 engine. Every 37 engine I've seen has the insert that you picture elsewhere. Thing is with these old Fords, nothing is ever totally black and white....it would appear that at least one [yours] 37 engine was produced with the earlier style rear cap. No worries, use it as is in conjunction with the inserted upper die cast piece in t5he block. It'll work....and, you don't need the oil return pipe the above poster alludes to. That item was discontinued in 1935.
Old 06-23-2017, 01:32 AM   #31
Brian
Brian's Avatar
Mate, you're a faster typist than me! My answer is the definitive answer you seek, and you are correct! Bolt it up and run it! Good luck, Brian
Old 06-23-2017, 01:37 AM   #32
hotrodjay
Drain pipe ended in early 35. Crankcase ventilation ended the need for a drain back pipe off the main cap. Also due to a better oil pump aswell. The question is does my main cap fit a lower seal or is it a 36 cap where it didn't exist yet? 37 was the 1st year for the lower seal. Maybe I have an early 37? Late 36? Does someone have a pic of a 37 main cap I can compare mine to?
Old 06-23-2017, 01:51 AM   #33
Brian
Brian's Avatar
The answer is your cap is the same style as in a 36 which does not have a separate insert as does a 'normal' 37 cap.
Old 06-23-2017, 01:58 AM   #34
hotrodjay
Brian, do you have a picture?
Old 06-23-2017, 02:01 AM   #35
hotrodjay
That's what I was thinking, need confirmation. Also you can see my 37 running realy good on fb. Look up hotridjay...at the end of the video i forgot to turn the ignition on...lol. I was excited...haha
Old 06-23-2017, 02:07 AM   #36
hotrodjay
Thankyou Brian, helping me confirm my theory..lol. I know 36-38 was a compilation of parts. Henry didn't wast anything...lol. check out my fb. Look up hotrodjay to see this engine running. I deleted the video from my phone. You can see it on my fb. Putting it back together the way it was, thanks everyone!!!
Old 06-23-2017, 02:16 AM   #37
Brian
Brian's Avatar
37 rear cap
