Old 06-17-2017, 01:32 AM   #21
sidhartha
sidhartha's Avatar
Default Re: car died, starts later
I thought they were some sort of high voltage bulb.
sidhartha is offline   Reply With Quote
Old 06-17-2017, 06:07 AM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
You need to use a resistor with the neon bulb.
Axman in the Twin Cities had some neon bulbs with the resistor for a buck or so a year ago.
If I get over that way I'll check to see if they still have any.
Old 06-17-2017, 07:25 PM   #23
Tom Wesenberg
I went to the Ax-Man surplus store today, but couldn't find any neon lights.
If you go to the electrical section of Menards or a hardware store, check for a circuit tester, as they also have a neon bulb.
Old 06-17-2017, 10:31 PM   #24
stillwater
thanks Tom, and everyone else for the help.
stillwater is offline   Reply With Quote
Old 06-18-2017, 12:06 AM   #25
Tom Wesenberg
Here you go, neon bulbs with the resistors for less than a nickel each.
http://www.ebay.com/itm/100Pcs-4x10m...IAAOSwT-FZCwVy
Old 06-18-2017, 10:57 AM   #26
stewwolfe
stewwolfe's Avatar
Okay, I'm going to show my ignorance here, but how does it light by just holding it on a spark plug. How is the ground for the circuit completed?
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 06-18-2017, 08:45 PM   #27
Tom Wesenberg
The high voltage is enough to make it light without a ground wire. I've even held one end of a fluorescent tube to a spark plug and made it light up.
Old 06-19-2017, 06:27 AM   #28
stewwolfe
stewwolfe's Avatar
Thank you, I never would have thought of that.
'31 40B
'31 68C
Old 06-20-2017, 02:21 PM   #29
sidhartha
sidhartha's Avatar
I managed to purchase some from Evil-Bay. Already have a bunch of clear tubes. Now I'll try to make some spark testers.
Old 07-01-2017, 03:48 PM   #30
stillwater
"Evil-Bay"...lmao
Old 07-04-2017, 04:54 PM   #31
Karl
Karl's Avatar
Getting Back to the original thread (late in my case)
My Model A did the same thing -eventually traced it to a faulty ignition switch that was jiggling closed on me. Replaced this and no problems since . The other thing to check is that the ignition terminals are not intermittently grounding on the gas tank behind the dash -Karl
Karl is offline   Reply With Quote
