Just replaced 2 yr old piece of fuel rated hose at the shop in '32 non ford product. Another "modern" gas episode--- to be replaced with metal gas lines, etc.
Now we're paying more close attention to gauges, valves, filters, seals and gaskets. |
Ethanol?
Stuff I buy by the foot from the car parts stores I've had on mowers for 15+ years no probs...always been ran on E10...There is junk fuel hose out there as ive ran across it before and it gets hard as a rock...
It is not all ethanols fault. I have had to replace all the low pressure fuel lines on a modern diesel tractor. They just get all soft and start oozing fuel.
Sorry but when you guy or gals going to stop using rubber hose for gas lines. I saw a totally restored 69 corvette burn up because a guy used rubber hose for a gas line. why
Brian |
If this is truly fuel rated hose (either A1 or B1, NOT A2 or B2 fuel VENT hose) and it failed after 2 years, then all our fuel hoses on everything we drive would be failing every two years...and that isn't happening (at least to me).
There is info missing in this story.
All steel from pedal to wheel |
#8 | |
| Thread Tools | |
| Display Modes | |
