Old 05-07-2017, 08:15 AM   #1
Woodie1
Woodie1's Avatar
Default Gear oil
How many miles would you drive your A to get the gear oil warmed up to drain it out & replace with fresh oil?
Woodie1 is offline   Reply With Quote
Old 05-07-2017, 08:28 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Gear oil
When I was playing with the temperature gun it was almost 40 miles before the temperature stabilized on a 60 degree day
Old 05-07-2017, 08:56 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
You gotta' OLD electric hot plate? That'll WORK.
Bill Warm
"THE ASSISTANT GURU OF STUFF"
Old 05-07-2017, 09:12 AM   #4
2manycars
2manycars's Avatar
Ford said to drain the gear case, add kerosene and run it a few minutes and drain that, then add new oil.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 05-07-2017, 09:21 AM   #5
BILL WILLIAMSON
A '26 Studebaker manual said, "Remove the shift tower & wash it out with GASOLINE"
Bill Scared
Old 05-07-2017, 10:47 AM   #6
WHN
For all my years owning Model A's, I just do one thing when draining fluids. Put pan under drain plug, open plug, and let drain for at least 24 hours. That's 60 years worth of service advice. U joint is another question.
Old 05-07-2017, 11:49 AM   #7
California Travieso
Send a message via Yahoo to California Travieso
Bill Warm
Bill,
Or just wait until summer when it's over 100 degrees in the San Joaquin Valley. That should do the trick. We'll get that here in the I. E. in a coule of months too.
David Serrano
California Travieso is offline   Reply With Quote
Old 05-07-2017, 11:59 AM   #8
katy
katy's Avatar
Ditto
Old 05-07-2017, 12:50 PM   #9
Terry, NJ
Terry, NJ's Avatar
I had to drain the gear case/differential on my 8N. Man that black goo was Thick! I found I could make it run faster by heating the bottom with a Propane torch. I wouldn't hesitate to warm it up somewhat that way.
Terry
Old 05-07-2017, 01:46 PM   #10
Woodie1
Woodie1's Avatar
Thanks for all the input.
Old 05-07-2017, 07:02 PM   #11
Synchro909
Synchro909's Avatar
The reason for flushing with Kerosene or whatever else is to wash out any metal fragments. I collect them with a magnet on the drain plug. I just let it drain over night, clean the magnet and refill.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-07-2017, 09:02 PM   #12
BILL WILLIAMSON
Originally Posted by California Travieso View Post
Bill,
David Serrano
David,
Once I did a 39 mile trip doing errands, on a 113 Degree day, in my ALL BLACK Coupe The only overheating was ME!!!
Bill Hot
Old 05-07-2017, 09:11 PM   #13
WestCoast
if you want tp flush rear end or tranny use diesel fuel, around 2.50 a gallon, kerosene around 10 dollars a gallon
WestCoast is offline   Reply With Quote
