I see Mac's discontinued the water pump I was waiting to order. Anyone have one or a rebuild kit or a good used one? I really just need the impeller as the fins are rotted off mine, but would take about anything.
Try posting in the "Swap Meet" section.
Try Renner's Corner. They are the "go to" guys for Model B parts. rennerscorner.com, (734) 428-8424
PS, I am glad you put this in the swap meet section as fourfords suggested Charlie Stephens |
Thanks Charlie, they have the rebuild kits but looks like they dont include an impeller. They also offer rebuilt units for $500. I'll keep looking or give them a call to see if they have any impellers they would sell.
#5 | |
Wow, $500 rebuilt ! There are two or three ways to go. PM sent |
I may have what you need. Will look tomorrow if you email me at [email protected]. Do you need a 1932 or '33-'34?
#8 | |
engine. Cools much better than the B pump. Google ford B pump adaptor. G.M.
www.fordcollector.com |
i had a 36 water pump on my A. the fan took out the pump
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
I have heard about the fan issue. I am on my second fan and radiator due to failure. Im trying to stay original and avoid the adaptor option. At this point im either going to send mine to renners or see if anyone has one for me. Thanks everyone
I have had one on my B engine for close to 30 years. Went on a lot of long
tours. Cools real good and never had a problem. I'm not sure what fan I am using, I think it's a 4 blade. G.M.
There's more to using the V8 pump than just buying the adapter. You may or may not have a better water pump, but you no longer have a fan unless you modify the V8 water pump pulley to attach a fan. That strikes me as something that would have to be done very carefully in order to avoid fan imbalance.
#13 | |
Curious as to how you attached a cooling fan to the V8 pump on you B engine ? Currently , there are no such adaptors made to put a fan to an early V8 pump. Kling's used to make an adaptor for such fan use to early V8 pump. He told me this year, that he hasn't made such adaptors for years now...'not enough demand' to justify making them. I have three different alum adaptors to mix/match various pumps to application, so am aware of those. Also , have good early V8 pumps that I'd like to use....but have to have that adaptor ! Last edited by hardtimes; 04-23-2017 at 12:43 PM. Reason: ............ |
#14 |
I don't have any information on these pictures.
Bob |
#15 |
Hey Bob,
Thank you for those pictures !Wonder if that is Kling's 'invention/equipment' on the front of V8 shaft ? Maybe someone has one or can identify this , over on the Model A side ? I don't know how to get these pictures over there with questions. I have the cyclone adaptor, one of three different adaptors on the shelf. Also have the other parts shown...except that fan holder ! Doesn't look complicated, eh ? Wish I knew machining, as I know that lots of inquiries for that adaptor in the past. |
#16 | |
#17 |
Before I went to a V8 pump I think I would add some speed equipment most of which uses a Model A water pump.
Charlie Stephens |
#18 | |
Charlie Stephens |
#19 |
Those are both '32s with two of the many casting variations encountered. There are even a few with Ford script on the casting and some aftermarket ones as well.
The outer ends of the grease fittings on the '33-'34 version are only about an inch apart. |
#20 | |
Now, that's just bragging ...geeze, nice engine bay !But, I wouldn't do that ! Well, maybe just one pic of lonely B in waiting ![]() BTW..thanks to David and you for you id help here ! |
| Thread Tools | |
| Display Modes | |
