Old 04-02-2017, 11:33 PM   #1
GB SISSON
GB SISSON's Avatar
Default Napa belts 59ab
I did a search 3 different ways and found threads about modified 59ab engines. Mine is stock. I need to go to napa tomorrow, our only auto parts store here and try to get the two belts. Anybody have part numbers or length? I think they are both 5/8 wide. Every time I get to this stage I trouble my way through it. Too long, too short. Thanks in advance.
Old 04-03-2017, 12:50 AM   #2
lodaddyo
Default Re: Napa belts 59ab
try these
Belt - Fan
NBH
2526366 $13.89 ('42-48 second belt...)
Belt - Generator & Water Pump
NBH
2524538 $17.69 (Main '42-48 belt)
lodaddyo is offline   Reply With Quote
Old 04-03-2017, 06:03 AM   #3
39portlander
39portlander's Avatar
Gary, I have a 59AB in my 39 P/U and have a B53 between the pumps. However I now run 12V and have a Certified auto electric Ford one wire alt. atop the intake and not a gen.
The belt that was on that Flathead was a Gates Vulco 666, and it ran like a devil. I also have a 39 Mercury with a Ford script 78-8620-A belt, hope this helps you. Scott
39portlander is offline   Reply With Quote
Old 04-03-2017, 06:54 AM   #4
OLD AS I
OLD AS I's Avatar
see my post titled "Fan and generator belt dimensions", I found NAPA 25-26366 DIDNT FIT, NAPA 24379 is perfect, so I have a brand new NAPA # 25-26366 for sale now, they wouldn't take it back as I didn't keep the packaging slv it came in
OLD AS I is offline   Reply With Quote
Old 04-03-2017, 08:28 AM   #5
RalphM
RalphM's Avatar
Best way I have found is to take a piece of rope about same dia of belt groove and wrap it around the pulleys. Mark where it comes together and either measure it, or just take it to the store with you. It will get you real close. Measure with your gen/ fan mount in the lower part of its travel.
RalphM is offline   Reply With Quote
Old 04-03-2017, 11:03 AM   #6
john in illinois
john in illinois's Avatar
After you get ameasurement,here is a gates chart,NAPA numbers are the same.
I use a TR22545 on my 59. The 11/16 wide work fine for 5/8
http://vaglinks.com/Docs/Catalogues/...Size_Lists.pdf
John These are truck and bus belts. I have one on my model A that has been on for years.
john in illinois is offline   Reply With Quote
Old 04-03-2017, 11:13 AM   #7
Karl Wolf
Karl Wolf's Avatar
If you need a belt length and have an old belt, cut it.
Lay it on a table, flat. Take a tape measure, mark off the length.
I do it in feet.
Put it around the pulleys- you could drill holes in the ends, use string to hold in place.
Use tape measure to determine gap.
This measurement and a size chart should get you what you need.
Karl
Karl Wolf is offline   Reply With Quote
Old 04-03-2017, 11:54 AM   #8
1942deluxe
1942deluxe's Avatar
My 59A-B has the NAPA 25-24538 and 25-26366 belts on it. There is supposed to be some slack (1/2) inch I think.
Old 04-03-2017, 07:38 PM   #9
GB SISSON
GB SISSON's Avatar
My work load today didn't allow me to drive the 25 mile round trip to Napa, but I found some old belts that sorta fit from an 8ba in my boneyard... This allowed me to circulate some wind and water on my runstand. I do have one more question and that is do I need to do something with the wiring on my generator so I can run it as an idler? Seems I read it needed to have one of the terminals to ground or some such so I don't ruin it. Hope it's not too late! And this has been great info!
