Old 04-02-2017, 03:54 PM   #1
Lawrie
Lawrie's Avatar
Default Rear hub bearing mod
I have just done the second bearing repair mod for my spare 33 rear end.
This fixes the worn bearing area in the hub and on the axle area also.
I machined the hub out to 82.5 mm,then shrunk in a sleave,bored that to 80mm.The hub was easy to machine out after I used a new insert on the boring bar. BUT it is very hard.
machine the axle OD down to 50mm and press on the bearing inner.
The bearings are two roller ones with a total load capacity of 9.6 tons each side.and a limiting speed of 9500rpm ,so should be safe there.
Only draw back of this,I have to remove the brake drum from the hub to machine it as my lathe is not quite big enough to do it with it on.
Lawrie
And ,thanks for fixing the add photo part, Ryan.
Old 04-02-2017, 05:01 PM   #2
meric42
meric42's Avatar
Default Re: Rear hub bearing mod
Nice work Lawrie, I have done a similar mod but using sealed ball bearings instead of roller bearings and found it to be a fantastic upgrade. I suspect that this mod should lessen the chance of breaking axles as well due to maintaining a more stable hub to housing alignment.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 04-02-2017, 05:11 PM   #3
Lawrie
Lawrie's Avatar
merc , the only drawback with sealed ball bearings is that there is no allowance for the axle to move in and out ,But if there was zero end float it would be OK, the rollers take a lot more load though ,
Lawrie
Old 04-02-2017, 05:53 PM   #4
Mart
Mart's Avatar
Excellent job, Lawrie. Would it be possible to give the exact bearing part numbers and the correct description of that type of bearing? Is the inner sleeve part of the bearing? (I mean bought, not made). What is the rough cost of those bearings?
I too had thought about the sealed ball bearing conversions and came to the conclusion that the in and out free play of the axle had not been taken into consideration.
Thanks for posting the pics and the how to description.
Mart.
Old 04-02-2017, 06:00 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Good work Lawrie. Looks like a good alternate approach for fixing an existing problem.
John
Old 04-02-2017, 08:05 PM   #6
Lawrie
Lawrie's Avatar
Mart, the bearings are NU 1010, the inner is a special , you can use the inner that comes with the bearings ,but need to make another couple of spacers to go in between both the inners and outers.
no drama.
Lawrie
Old 04-02-2017, 10:42 PM   #7
quickchange34
quickchange34's Avatar
Nice post, something of interest for a change.
quickchange34 is offline   Reply With Quote
Old 04-03-2017, 04:29 AM   #8
Kpar
Kpar's Avatar
Lawrie, is the normal grease fitting maintained or is it just repack the bearings at klm's intervals ?.
Kpar
Kpar is offline   Reply With Quote
Old 04-03-2017, 05:09 AM   #9
Lawrie
Lawrie's Avatar
Keith,all the grease nipple stuff is still there,drop over and have a look, I,m just doing up a drawing.
lawrie
Old 04-03-2017, 06:41 AM   #10
Ol' Ron
Ol' Ron's Avatar
Atta Boy Mate. I love fixes like that. Good thinking. My lathe is a 13" P&W, but I have a friend with a 16" if I need it. Just replaced my 3 jaw chuck with a 90 year old one. Had to make a spindle adapter. Runout is only .002" pretty proud of that. Keep em Runnin
Ol Ron
