Old 03-09-2017, 12:25 PM   #1
JimG
JimG's Avatar
Default Re: hard steering - radials or bias ply
My 34 is similar, but I figured it was because I have relatively wide radial tires on the front as compared to the 5.5" wide tires the car was originally supposed to have - lots of friction between the tire and the road. Mine are 8.9" wide. What width tires do you have? Once you are moving it steers OK. I agree that having them properly inflated makes a big difference - which makes me think it is the friction between the tires and the road. Your test on the plastic sheet would also tend to confirm this.
JimG is offline   Reply With Quote
Old 03-09-2017, 02:58 PM   #2
carguybill
carguybill's Avatar
I currently have the original type 17" bias ply tires which I inflate to 35psi. The bigger footprint of the radial would seem to me to be problematic. Truth be known, I probably just need stronger arms, but my 80 year old body is tiring.
carguybill is offline   Reply With Quote
