Old 03-01-2017, 07:26 PM   #1
northeastcarnut
Question Is there a good chemical to quiet lifter in my '51 Lincoln flathead
I'm still trying to solve my problem with a noisy lifter in my '51 Lincoln flathead. Is there a good reliable chemical I can add? The noise appears only after the engine runs and warms. When cold, it's quiet and runs great. I have run lots of Mystery Oil in the crankcase, but no help. I'm now running fresh 40W non detergent oil.
northeastcarnut is offline   Reply With Quote
Old 03-01-2017, 07:40 PM   #2
30-9
Default Re: Is there a good chemical to quiet lifter in my '51 Lincoln flathead
Good stuff:
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 03-01-2017, 08:00 PM   #3
alanwoodieman
might need to adjust one valve. put a vacuum gauge on the engine and see if there is any variation between cold and hot readings. I had an adjustable lifter that would self adjust, fixed that one and now I have another one that does it when it is hot
Old 03-01-2017, 08:00 PM   #4
Pilot31135
Pilot31135's Avatar
PB Blaster trans valve fix, if you can find it.
Pilot31135 is offline   Reply With Quote
Old 03-01-2017, 08:38 PM   #5
Tinker
Tinker's Avatar
I wish the barn had the "Like" feature like the Hamb.
Old 03-01-2017, 09:48 PM   #6
cmbrucew
cmbrucew's Avatar
You can, scroll back to the OP #1 on the red bar select Rate this thread.
Cast your vote.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-01-2017, 10:20 PM   #7
Tinker
Tinker's Avatar
Cast your vote.
Bruce
I get that Bruce and thank you, I was thinking more about agreeing with an answer. Might eliminate a lot of double posts. Not that I'm saying anything is wrong with it now.
Old 03-01-2017, 10:44 PM   #8
WestCoast
your first mistake is running non detergent oil in an engine with hydraulic lifters, detergent oil removes gunk and sludge built up in an engine. try running 4 or 5 oz of mmo in our gas. it could be the valve sticking in the guide
WestCoast is offline   Reply With Quote
Old 03-01-2017, 11:40 PM   #9
tubman
tubman's Avatar
"Like"
Old 03-01-2017, 11:50 PM   #10
GB SISSON
GB SISSON's Avatar
Putting a chemical in to quiet a noisy lifter seems more like what would be done to quiet a hydraulic lifter that was collapsed or sticking. In my somewhat limited experience with these flatheads a noisy one most would most likely need to be adjusted to quiet it down.
Old 03-02-2017, 12:43 AM   #11
Brian
Brian's Avatar
The Lincoln is indeed running hydraulic lifters, hence the op's question.
Old 03-02-2017, 01:46 AM   #12
petehoovie
petehoovie's Avatar
Old 03-02-2017, 02:33 AM   #13
40 Deluxe
!st step is to get that non-detergent oil out of there! That stuff is only good for oiling bicycle chains. Hydraulic lifters caused a lot of trouble before high detergent oil became available. "Collapsed" lifters were common. Sludge and varnish deposits caused the little check balls to hang up or not seat properly, or gummed up the internal plungers. Rislone was one product offered back then that seemed to work.
Old 03-02-2017, 03:16 AM   #14
51 MERC-CT
51 MERC-CT's Avatar
Yes, indeed RISLONE is what worked for me when a noisy hydraulic lifter problem needed attention.
Old 03-02-2017, 04:11 AM   #15
flatford8
flatford8's Avatar
Does a '51 flathead have hydraulic lifters?........ Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 03-02-2017, 05:16 AM   #16
51 MERC-CT
51 MERC-CT's Avatar
Yes. '51 Lincoln flathead has hydraulic lifters.
Old 03-02-2017, 05:49 AM   #17
flatford8
flatford8's Avatar
Ok. Thanks
Old 03-02-2017, 08:36 AM   #18
KGS
KGS's Avatar
Do a fresh oil change with detergent oil minus 1 quart. Add a full quart of Marvel Mystery Oil to replace the one omitted in the oil change. Run the car for 100 to 200 miles and do another oil change. This should cure the noisy lifter. If not, run the car another hundred miles or so and repeat the MMO procedure. Ken
KGS is offline   Reply With Quote
Old 03-02-2017, 09:59 AM   #19
rotorwrench
rotorwrench's Avatar
Hydraulic tappets generally have a little ball bearing in them that acts as a one way valve. If the seat or ball has deteriorated to the point that it allows excessive leak down, the tappet assembly should be replaced. Crud can get in there and cause leakage too but sometimes you have to remove the lifter and clean the crud out manually. A leak down test can be performed before considering whether to put it back in there. Sometimes a unit just has bad clearances in the little piston or its bore. This can also cause excessive leak down. If that's the case, the unit would have to be replaced.
Old 03-02-2017, 10:41 AM   #20
blucar
blucar's Avatar
It is hard to believe that anyone would run a non-detergent oil in any engine in this day and age.
I have ran nothing but detergent oil, either Union Oil Royal Triton or Castorl GTX 20/50 in my 59AB engine since 1954. The only reason I switched from Royal Triton was because Union Oil quit making it.
I use the oil recommended by the vehicle manufacture in my newer, modern vehicles.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
