Old 01-13-2011, 01:58 PM   #1
George Miller
George Miller's Avatar
Default 5 Main bearing Model A block
Here is a picture of the junk block that I put 5 mains in for the cam and crank.
This is to go with the head that I made last summer.
George Miller is offline   Reply With Quote
Old 01-13-2011, 02:06 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 5 Main bearing Model A block
Looking good! Did you make your main webs, --or are these some that Dan Price made up a few years ago?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-13-2011, 02:07 PM   #3
kelley's restoration
kelley's restoration's Avatar
so why is it junk
or...
is this just a proto type so you can figure out what you will need to do to a good block to make it work without messing up a good block
what kind of steel are you using for the inserts (extra mains)
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 01-13-2011, 02:08 PM   #4
also what crank are you using
tk
[email protected]
Old 01-13-2011, 02:09 PM   #5
George Miller
No I made my own.
Old 01-13-2011, 02:22 PM   #6
d.j. moordigian
d.j. moordigian's Avatar
George,
Your taxing my head, Chevy ll crank, Chevy rear main. Built those for midgets back
in the 70's. Have a friend doing an A for land speed, 5 main AL girdle , one piece, custom crank. Send more photos!
Dudley
UH...I take that back, it's a V/8 crank!
d.j. moordigian is offline   Reply With Quote
Old 01-13-2011, 02:23 PM   #7
Larry Brumfield
And to think I've seen you call yourself an Ol' Country Boy .....
That's outstanding work, George. Good job!
Larry Brumfield is offline   Reply With Quote
Old 01-13-2011, 02:43 PM   #8
George Miller
Originally Posted by kelley's restoration View Post
so why is it junk
or...
tk
The lifter guides are broken, I will be redoing them any way. I would rather save the good blocks, some one might need them for a stock engine down the road.
Old 01-13-2011, 02:45 PM   #9
George Miller
tk
Not sure what crank and cam at this time. It will be some kind of chev, I think.
Old 01-13-2011, 02:46 PM   #10
George Miller
Well I was born in the country, USA MICH.
Old 01-13-2011, 03:04 PM   #11
James Rogers
James Rogers's Avatar
George, someday I am gonna have to come down there and bench race some with you.
James Rogers is offline   Reply With Quote
Old 01-13-2011, 03:13 PM   #12
Kohnke Rebabbitting
When you get mine done, call me. Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 01-13-2011, 03:15 PM   #13
MrTube
MrTube's Avatar
George : What kind of power are you hoping to get out of this engine when all is said and done?
MrTube is offline   Reply With Quote
Old 01-13-2011, 03:48 PM   #14
George Miller
I would like 1 hp per cubic inch. They done that many years ago, so I should be able to do it now.
Old 01-13-2011, 03:51 PM   #15
BRENT in 10-uh-C
The lifter guides are broken, I will be redoing them any way. I would rather save the good blocks, some one my need them for a stock engine down the road.
Good reason there George!!
Why I had asked was Dan Price had cast up some saddles a few years ago and still had a couple of sets the last I checked. I almost bought a set until I found a 5-main girdle to use.
Another crank to consider is the Hercules crank out of a forklift engine. I think the bore spacing was pretty much the same and it gave a ¼"(??) stroke. Are you gonna make your own billet rods?
As far as getting 1 hp per cu in, Hudson pretty much was doing that with their 7X Flathead. I'd say that 1.25 --or even 1.5 hp per cu inch is very do-able with your combination!
BRENT in 10-uh-C
Old 01-13-2011, 03:51 PM   #16
George Miller
Come on down. Do you still go to old maggie valley meet in the fall. We could meet there.
Old 01-13-2011, 03:55 PM   #17
George Miller
I will probably make my rods out of 7075. I have made some in the past.
Old 01-13-2011, 05:19 PM   #18
Flathead
Flathead's Avatar
This is a very interesting project! I like your style, dig in and do it! How do you plan to anchor those extra main bulkheads? They look welded in, will that be it? Are you going for a big stroke? Thanks for sharing this with everyone on the Barn.
Flathead is offline   Reply With Quote
Old 01-13-2011, 07:04 PM   #19
George Miller
Yes they are weld in also will be pinned, and the main studs go all the way through the block just like the original, except they will be studs.
No going for a shorter stroke to reduce piston speed. Will increase the engine speed to make up for the loss of stroke.
Old 01-13-2011, 07:12 PM   #20
George Miller
Did you not receive it this week, is the check in the mail.
