Old 09-27-2016, 09:46 PM   #21
1stford
1stford's Avatar
Default Re: 1936 Truck restoration
I'm still getting caught up on the progress of this thing. I had all the frame parts powder coated and I got it back about a month ago. If any of you guys see anything that looks wrong let me know. I'm still learning.
1stford is offline   Reply With Quote
Old 09-27-2016, 10:22 PM   #22
Scott H in Wheaton
Scott H in Wheaton's Avatar
Where's all the junk?
Scott H in Wheaton is offline   Reply With Quote
Old 01-24-2017, 03:25 PM   #23
1stford
1stford's Avatar
Does anyone have any pictures of the fuel line location from fuel tank to engine. I'm wanting to make sure I run it correctly.
Thank you
Old 01-24-2017, 04:40 PM   #24
Jeff/Illinois
Jeff/Illinois's Avatar
Beautiful. Can't wait to see the finished product well done.
Old 01-24-2017, 05:05 PM   #25
V8COOPMAN
V8COOPMAN's Avatar
Thank you
Here's a couple of pics of a '40 chassis (essentially the same thing) that will give ya an idea of the path from the tank, to where the hard line stops at the firewall area. It basically runs inside the main frame rail, and is clamped securely every so often. The rest of the way is easy to run, up the firewall. Use STEEL lines. What you see in the pics is copper-coated steel......NOT copper lines. Pay no attention to the copper vacuum lines going to the Columbia O/D. Hope this helps! Thanks to KUBE for the pics of one of his beautiful restorations. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-24-2017, 05:20 PM   #26
V8COOPMAN
V8COOPMAN's Avatar
Here's one last pic to show the rest of the run. Note the copper-colored line at lower right of pic, near frame/firewall junction. It heads UPward, then turns horizontally to meet with the soft line, which ends-up at the fuel pump. This is all STOCK '40. DD
T5 W/TORQUE TUBE
Old 01-24-2017, 05:24 PM   #27
Byron Warwick
Byron Warwick's Avatar
Congrats. on starting your restoration. I know some like to see the original scratched up paint just waxed and kept as is. However by the looks of your frame work, you are going to make it look like new and i think it will look great. Mine took 10 years to complete. Lots of help on "The Barn".
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE !
Byron Warwick is offline   Reply With Quote
Old 01-24-2017, 07:11 PM   #28
1stford
1stford's Avatar
That 40 looks awesome. Thank you guys for the help. I'm going to try and post some more recent pictures of the project.
Old 01-24-2017, 07:17 PM   #29
Talkwrench
Talkwrench's Avatar
All to shinny.......
Old 01-24-2017, 10:59 PM   #30
Ron Pilger
Ron Pilger's Avatar
Near as I can tell there is only one problem with this truck.....that being that this truck is not in my garage. Oh, how jealous I am. What an outstanding specimen of a truly great year of Fords finest work. Best of luck in what appears to be a first class build.
Ron Pilger is offline   Reply With Quote
Old 01-25-2017, 06:05 AM   #31
coupeA31
Nice truck! Do you have may be a horn in your spare part box for my 35 ford pickup?
[email protected]
coupeA31 is offline   Reply With Quote
Old 01-25-2017, 07:30 AM   #32
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Love your truck, and your shop space is like a small piece of heaven!
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 01-26-2017, 03:14 PM   #33
1stford
1stford's Avatar
I'm sorry I don't have any extra horns. My truck appreciates all the nice things you guys have said. I told her and she blushed. I do have these two parts and I'm not sure where they go, any ideas?
Old 01-26-2017, 03:42 PM   #34
VeryTangled
VeryTangled's Avatar
Hi Everyone. Those are splash pans. Mount from underneath. The pointy one with the hole goes under the radiator. The other one is one of the sides. I think there are three. Almost all of them look like yours, off the car, stacked with the battery cover, cuz when on they prevent access to dizzy for example. Still, they help cooling, and water coming from below onto the engine bits.
-Jeff H
Last edited by VeryTangled; 01-26-2017 at 05:01 PM. Reason: Adding photos from internet search
Old 01-26-2017, 10:09 PM   #35
1stford
1stford's Avatar
Another question, sorry I've got so many. In regards to the running boards on the truck, were they just painted from the factory or is there some type of cover that should be over the running board. If there's something that goes over it what would it be?
Old 01-26-2017, 10:45 PM   #36
VeryTangled
1stford, I don't have one of those beauties, but my impression is that the running boards on a '36 'commercial' 1/2 ton are painted with nothing on top.
-Jeff H
Old 01-27-2017, 02:09 PM   #37
1stford
1stford's Avatar
Does anyone happen to have any pictures of the above mentioned splash gaurds installed? I can't figure out where they bolt up to.
Thanks.
Old 01-27-2017, 02:15 PM   #38
Bored&Stroked
Bored&Stroked's Avatar
You're doing a great job and I'm very happy to see that you're continuing with a flathead, a 39 transmission and sticking with an original type build. Very nice work - can't wait to see when it is done.
Old 01-27-2017, 03:44 PM   #39
kiwitony
kiwitony's Avatar
Yes you are doing a great job, The only problem that I can see is you have put the brake pedal on the wrong side. HaHa. Tony.
kiwitony is offline   Reply With Quote
Old 01-27-2017, 11:57 PM   #40
1stford
1stford's Avatar
Here are a couple of pictures that bring it up to where I am in my project. Thanks for looking.
