Old 01-22-2017, 03:18 PM   #1
newshirt
newshirt's Avatar
Default Rear wheel bearing play
How much play should each roller in the rear wheel roller bearing have?
I didn't measure, but it looks 1/16" of an inch.
I can grab rollers and move them around quite a bit. Two rollers can be pulled together so their outer surfaces touch. Every roller rattles when I shake the whole bearing, like a little tambourine.
Is 1/16" of an inch really bad?
Ray White
newshirt is offline   Reply With Quote
Old 01-22-2017, 03:55 PM   #2
larrys40
Default Re: Rear wheel bearing play
Ray,
It is normal for them to be like that. if you fit the bearing itself on the axle housing you will find more of the fit. The things to look for in the bearing and races is any pitting or looseness of the cage on the bearing.
on the axle housing surface look at the bottom surface where the load is and there should not be any galling or roughness or grooves on the axle housing bottom.
Hub: inside the hub should be free from pits and galling as well. If so you there is a fix for that. Before I would invest in the fix I would look at the hub key way and surface to make sure there's no damage and additionally I would not invest any more in a hub that has hub studs welded. The fix is it can be sleeved with a kit from Snyders or Brattons that uses a sleeve installed in the hub ( following directions of course) and it now uses a V8 68-bearing that is the smaller profile. It will then work as normal onto the axle housing. I have a KR Wilson hub bore gauge they had available in the day to check for bore wear but usually the checks I gave you will be sufficient.
that's the long and short of it!
Larry Shepard
larrys40 is offline   Reply With Quote
Old 01-22-2017, 04:04 PM   #3
Mitch//pa
What Larry said:::
Beware of the repop rear bearings as there is a lot of defective junk floating around... people have lost their wheels and damaged internal components
Old 01-22-2017, 04:40 PM   #4
newshirt
newshirt's Avatar
The bottom of the axle housing is bright and shiny. The diameter is 2.070 at all points around the housing.
There are some lines on the top of the axle housing, but they are not grooves. I cannot scratch them with my fingernail.
There is a small gouge at the 5 o'clock position of the axle housing, near the outside. I believe that occurred recently when the axle broke and wheel fell off.
Ray White
Old 01-22-2017, 04:47 PM   #5
Dave in MD
Amen to what Mitch said. Two of our club members had the repops just about to the failure stage. You can easily spot the repop bearings as they have 12 rollers as opposed to 14 on the original correct type. Also the cages on the ends of the rollers are held in place by all 14 roller pins. The repops have six pins holding the end cages (one between every two rollers). On both cars the pins and cages had cut a significant groove on the inside of the hub. One car had about 7,000 miles while the other had over 8,000 miles.
If one of the rear bearings locks up while driving it could be very dangerous.
I'd recommend everyone check the rear wheel bearings in their car.
Dave in MD is offline   Reply With Quote
Old 01-22-2017, 05:02 PM   #6
Mitch//pa
Dave thats great indentifying information... i have not dealt with the repops for the reason of failure so i did not know that... didnt some repops not have the spiral cut into each roller?
Old 01-22-2017, 05:52 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
From the looks of the damaged bearing surface, I'd be replacing that axle tube with a good used one. Be sure to check the differential for correct fit when doing this. There should be just enough pressure to have a very slight drag.
Old 01-22-2017, 06:23 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
If you look at every vendors catalog, the picture clearly shows only 12 rollers. So I guess they are all NFG.
Where would a good place be to find the proper bearings or are we SOL.
Old 01-22-2017, 06:29 PM   #9
Smooth_One
Smooth_One's Avatar
My bearings are old ones and I'll be running those because they're in great shape with almost no pitting.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 01-22-2017, 06:36 PM   #10
larrys40
I agree with Tom said that for a long term fix I would probably plan on replacing that housing or getting it sleeved. Remember if you "replace it.... your carrier bearing preload will most likely change. A rear axle rebuild or removal to check out and fix properly is probably in the future.. if not present!
The original "A" bearings had a spiral on the rollers. The later Ford and replacement bearings do not. As Mitch, I've not dealt with the repros as I always have a supply of original parts on hand.. which is preferred. They are also probably cheaper than the inferior aftermarkets.
search ebay or dropping one of us a PM will give you a bearing or two if you need them.
Also.. as for a regular maintenance item it's a good idea to pull the hubs every couple of years and hand pack them with your preferred grease. I like the heavy Sta-Lube fiber grease in the green can. Others like something else which is fine... just do it.. and torque the axles tight ( I go to 150 ft lbs) when done.
Larry Shepard
Old 01-22-2017, 06:58 PM   #11
Dave in MD
Mitch and Larry,
Yes some of the repop bearings have the spiral grease groove while other repops do not. So you cannot rely just on the grooves being there. The bearings that failed on two of our club member cars did have the grooves even though they were worn down. Both members found the problems while doing their greasing maintenance. Also, both owners had been using the Sta-Lube grease.
Dave
Old 01-22-2017, 07:11 PM   #12
Mitch//pa
Dave
Thank you very much.. i know Brattons was selling those bad ones as they ate a lot of parts from it.. and i mean parts to fix all the damage caused to peoples cars... not sure about the other vendors.
Old 01-22-2017, 07:58 PM   #13
larrys40
Wow ! Good to know that and thanks for bring that up. I've seen a lot of bearings but have NOT seen the repros with the groove.
Probably not hardened adequately so self destructed
Larry
Old 01-22-2017, 09:42 PM   #14
Tom Wesenberg
If you're not planning to replace the axle tube at this time, at least run a smooth mill file over the high spots where it was damaged. You can get by for a while, but I'd feel better for long trips if it had a better bearing surface, which for me would be a different axle tube.
Old 01-22-2017, 09:50 PM   #15
Mitch//pa
They should make a tap on sleeve like what is available for say a crank shaft etc on a modern
Old 01-22-2017, 10:40 PM   #16
newshirt
newshirt's Avatar
What are the consequences of not replacing the axle housing? Will it tear up the roller bearing? Tear up the rest of the bearing surface? Lock up the rear wheel?
Ray White
Old 01-22-2017, 10:47 PM   #17
Tom Wesenberg
As long as the high spots are removed, you'll probably go a long time with what you have. It's when you have metal flake off, or dirt, etc. get into the bearing that it goes quickly. In reality you gouge in the metal hasn't removed a large percent of support, but if you get a chance to replace it, I'd still feel better knowing I had a perfect part.
What was the reason the axle broke?
Old 01-22-2017, 10:55 PM   #18
midgetracer
midgetracer's Avatar
Snyders has a sleeve that repairs the axle housing. It does require machining to fit. The sleeve is only $22, but the machining will be a bit more.
midgetracer is offline   Reply With Quote
Old 01-22-2017, 11:04 PM   #19
Tom Wesenberg
Plus you'll have to buy a different bearing to fit.
Old 01-22-2017, 11:21 PM   #20
Mitch//pa
What im talking about is a sleeve saver.. its only a thousands thick
If u ever saw them for modern applications
If something is grooved from a lip seal riding ,, the sleeve makes a new surface
