Old 01-09-2011, 08:41 AM   #1
jon101
Default coupe carpet
Can anyone direct me to a pattern or template for the carpet for a "31 coupe? I have the perfect carpet piece and would like to make my own. Thanks
jon101 is offline   Reply With Quote
Old 01-09-2011, 08:54 AM   #2
Aerocraft
Aerocraft's Avatar
Default Re: coupe carpet
I recently made a front carpet for my '29 Briggs Town Sedan. I first taped together pieces of thin cardboard cut to fit small areas of the floor. It was quite easy to come up with a pattern. By then cutting the carpet slightly oversize, I was able to come up with a fit that was quite satisfactory. Gar Williams
Aerocraft is offline   Reply With Quote
Old 01-09-2011, 09:26 AM   #3
1931 flamingo
1931 flamingo's Avatar
I used sheets of posterboard when I did mine, Take your time, and only cut once. Change razor blades often unless using scissors.
Paul in CT
