Old 11-08-2016, 08:06 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Default Re: alternator on a Mercury 4-bolt manifold
Originally Posted by 40cpe View Post
It has been a while since I bought this bracket. I just went back to Speedway site and found this "note":
To use this bracket on a wide belt car or truck you would need to cut approximately 1/2" to 5/8" from the wide boss on the base of the alternator. You would also need to cut a similar amount from the spacer supplied with the bracket. This must be done to get the alternator pulley to line up with the drive belt.
You knew that! As you're now remembering, a good hot rodder has to be apt at carving pieces to fit where they once wouldn't fit. Get that hacksaw blade warmed-up. DD
Click Links Below __
T5 W/TORQUE TUBE
