Old 10-24-2016, 12:33 PM   #21
Flathead Dave
Flathead Dave's Avatar
Default Re: car wheel dollies
I use Harbor Freight dollies. Have had them for 7 years and have never had a problem with them. I use them every single day. Never greased them. Never had to do anything to them.
"Some people are like slinkys. They're not really good for anything but they sure bring a smile to your face when they're pushed down the stairs"....
Flathead Dave is offline   Reply With Quote
Old 10-24-2016, 02:10 PM   #22
Fred K-OR
Fred K-OR's Avatar
Then get what you want. Seems all dollies work!
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 10-24-2016, 05:03 PM   #23
majohnson00
I bought two set's, HF, one for my 52 Chevy 2 dr. and one for my 1990 Buick Reatta Convertible. Both set's collapsed where the wheels attach as I tried to move the vehicles in place on the concrete floor. I greased all the roller bearings when I assembled them and tightened the bolts down correctly. JUNK I was planning to buy a 3rd. set my 31 Model A Tudor, but not now. Again, JUNK, IMO.
majohnson00 is offline   Reply With Quote
Old 10-24-2016, 06:08 PM   #24
nhusa
nhusa's Avatar
I have a set of HF dollies for my model A.
They are great!
I use my but to push.
I make sure the concrete floor is clean and it does take a bit of effort to get the casters pointed in the right direction.
They make it easy to fit my T and A into the garage with my wife's van
nhusa is offline   Reply With Quote
Old 10-24-2016, 07:54 PM   #25
JRShaw
JRShaw's Avatar
Smile Re: car wheel dollies
I have a set of the four (4) Harbor Freight dollies, and I have replaced the steel wheels with some hard rubber ones, and greased any of the possible friction points in the process. This should allow me to move my '31 roadster around quite easily (I hope). Presently the car is taking up two-spaces in the garage and my wife's car is outside (ouch).
Joel R. Shaw
Fairport, N.Y.
JRShaw is offline   Reply With Quote
Old 10-25-2016, 11:23 AM   #26
old31
Originally Posted by Mitch//pa View Post
The cheap ones don't roll good and easily flip over / kick out from under the tire... Beware
On these you get what u pay for..
I had a cheap pair kick out and shot into my ankle... Lucky it didn't snap it
"Lucky it didn't snap it"
I hope that you were talking about the dollie
old31 is offline   Reply With Quote
Old 10-25-2016, 11:32 AM   #27
C26Pinelake
I have two sets of HF and they work fine. Just keep them greased. No need for a commercial set in a hobby garage. Some people knock HF no matter what the product often with no basis. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-25-2016, 12:15 PM   #28
Mitch//pa
Nope it shot out like a bullet...
We have nice straight smooth concrete sealed floors
Old 10-25-2016, 01:15 PM   #29
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I made a set out of aluminum with angle mounted on top in the shape of a square. they double as car dolly and a jack stand dolly for a frame, or I've even rolled my car around without wheels, when doing brakes ect. I made them too small at first, and when the wheels turned just right, it was tippy.so I made the base bigger. You do have to be sure you have a smooth surface w/o any debris.
Old 10-25-2016, 04:58 PM   #30
BobWatts
BobWatts's Avatar
Reading through HF's reviews it seems they had some updates and the newer ones are said to work much better with less flexing etc than the old. That being said I only have used 4 new ones purchased in July 2016. The first time I used them when letting the car down upon contact they shot out and luckily didn't hit me. After that close call I drew a center line both ways and am careful to locate the wheels on center plus make sure the brake is on when slowly letting the car onto them with no problems at all after many uses with the 36 Coupe and the 29 Pickup on a pretty crappy floor. Making sure the casters are pointing the right direction is the secret if there is one.
BobWatts is offline   Reply With Quote
Old 10-25-2016, 08:06 PM   #31
desotoguy
Compare the size of the wheels on the castors. Larger the diameter, easier the roll. Beware that hard rubber wheels will flat spot if left with a load for an extended period
of time, steel is best. Garage floor must be clean to move the car.
desotoguy is offline   Reply With Quote
Old 10-25-2016, 10:37 PM   #32
daveymc29
daveymc29's Avatar
Thanks everyone. I bought the midrange set from HF. Lubricated and put a pair under the rear wheels after I drove the front close to where I want to end up. A good shove completes the move. I may go back and get another pair, this time of the ones that include the ability to just slide them around/under the tire while car is on the ground, them pump the jack a few strokes to get car off the ground. We'll see.
daveymc29 is offline   Reply With Quote
Old 10-26-2016, 07:42 AM   #33
Lew
I bought a set of "roll master" car dollies probably 20 years ago (before HF had them) and I just love them. They have a flat bottom, so a jack stand could be placed in them for additional uses. They were expensive at the time, but well worth it.
Lew is offline   Reply With Quote
Old 10-26-2016, 02:32 PM   #34
1ton
I'm using the HF wooden furniture dollies for the model a. They have the same capacity as their steel ones and are eight bucks a piece. I've had no problems at all and the tires are trapped in them so they cant fall out.
1ton is offline   Reply With Quote
Old 10-26-2016, 04:15 PM   #35
Cool Hand Lurker
Cool Hand Lurker's Avatar
And we have a WINNER !!!
Cool Hand Lurker is offline   Reply With Quote
Old 10-26-2016, 04:26 PM   #36
justold
The cheap ones "HF" don't roll good and easily flip over / kick out from under the tire... Beware
X2 just junk . I had a set the steel casters were not drilled on center .
justold is offline   Reply With Quote
Old 10-26-2016, 06:36 PM   #37
Vic in E-TN
Angry Re: car wheel dollies
I had a great idea. I set a jack stand on each of four more expensive dollies. I took the wheels off and pushed the car a little. The stands were not stable and the car wound up on the floor resting on the back of the rear fenders, bending them. That was an expensive lesson.
Vic
Vic in E-TN is offline   Reply With Quote
Old 10-26-2016, 07:54 PM   #38
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, I've seen that also. I bought 4 of the 10" pneumatic tires to make a cart for my lawn tractor. I had to stick my fingers in the ball bearings and give the wheels a spin to make sure they spun straight.
Old 10-27-2016, 01:45 PM   #39
Cool Hand Lurker
Vic
Like this? Would it have worked better if the jack stand was welded to the dolly or do you think they would still be unstable without a larger base?
I was going to do the same thing, thanks for the warning.
Old 10-27-2016, 01:48 PM   #40
AL in NY
AL in NY's Avatar
Can't beat hydraulic wheel dollies, NO JACK NEEDED.
AL in NY
AL in NY is offline   Reply With Quote
