Old 10-16-2016, 01:59 PM   #41
Flat Ernie
Flat Ernie's Avatar
Default Re: FINALLY…T5 WITH Torque Tube in a ‘35-’40 Ford...The WHOLE STORY!
Great work. When I was doing all my tape measure engineering, I figured out that if my adapter between the rear-most face of the Jeep T5 and the front face where the rear clamshell bolts to was about 2-1/8" (going on memory only), I could use a stock 33/34 Torque-tube and driveshaft without having to shorten anything. Apart from the center section surgery required, it would be close to bolt-in.
The Jeep T5 shifter is about 7" more rearward than stock - again, I'm going on memory - I haven't fiddled with any of my early Ford stuff in a few years as everything has been on hold based on life events.
Good info, great conversion, and it sounds far more complicated than it is once you solve the challenge of the spline adapter & seal plate...it's really pretty simple.
I think I also figured out that using the Jeep 5th gear with the Astrovan cluster came up with an aggressive .59 OD ratio, which allowed a nice cruising RPM with an early Ford rear stock gear assembly.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 10-17-2016, 09:29 AM   #42
Kube
Super Moderator
Kube's Avatar
I apologize to the guys that did all of this amazing work in that I am just now reading of it and just now bestowing my sincere praise of your efforts and results.
I don't normally look at posts that reflect modified vehicles. Regardless of the fact I am a purist, I so very much appreciate any venue wherein the "players" have shown keen insight, intellect and execution.
I have an engineering and tool making background so feel I can offer with confidence that these guys went to great efforts to make this happen at the level of quality depicted.
Congratulations to a job well done!
Old 10-17-2016, 11:45 AM   #43
Heard
Heard's Avatar
Originally Posted by JRHASZARD View Post
Senor Heard
Is the WILCAP adapter the: BH 59A-350 ; BHA FHFT- 350, or the BHA -292 FTS?
Thanks, John
John,
It is the 59a-350.
Heard
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 10-17-2016, 11:56 AM   #44
Heard
Heard's Avatar
Ernie,
You are correct I believe that a stock 33/34 tube might have worked. It would be VERY close and I almost went this way, but I thought since I already had the '35 tt/shaft, I'd modify it. Dick could probably provide some input on this.
And you are correct, it sounds WAY more complicated than it really is. If I can do it, almost anyone on the Barn can do it. After all, I'm just a redneck with a welder. And I ain't very good with it either....
Also, you should know that your old T5 posts are what really started this whole thing so I'm puttin' part of the blame on you!
Heard
Old 10-17-2016, 11:54 PM   #45
JRHASZARD
JRHASZARD's Avatar
Thanks ! We should be in St.Augustine for Jan-Feb. I would like to drop by on the Harley to see your work if that is OK.
John
JRHASZARD is offline   Reply With Quote
Old 10-18-2016, 12:09 PM   #46
gearhead1952
gearhead1952's Avatar
Great write up thank you. That torque tube weld is so pretty. Wish I could weld like that.
gearhead1952 is offline   Reply With Quote
Old 10-20-2016, 02:30 PM   #47
V8COOPMAN
V8COOPMAN's Avatar
Ernie,
And you are correct, it sounds WAY more complicated than it really is. If I can do it, almost anyone on the Barn can do it. After all, I'm just a redneck with a welder. And I ain't very good with it either....Heard
Heard and Flat Ernie mentioned the possible use of a '34 torque tube and drive shaft. During the last couple of weeks while Heard and I were discussing measurements and methods for shortening the torque tube, Heard mentioned to me that he thought that a modified T-tube length should probably be about 61-7/8". Now while I'm not usually good for very much of anything, I have this uncanny thing about remembering certain numbers. I thought I remembered a '33-'34, V8 T-tube length being something like 61-13/16" (NOTE: 4-cylinder T-tubes and d-shafts are 1-1/2" shorter than V8). Sure enough, when I checked my notes, Heard's measurement indicated that in all likelyhood, a V8 torque tube from the aforementioned '33-'34 models should bolt-in "as-is"....un-modified! I suppose it's also possible that the driveshaft may have worked as well, but we didn't get that far, as we didn't have a '34 d-shaft to measure accurately.
I'm not surprised that Flat Ernie was already on to this nifty bit of old Ford trivia, 'cuz I was aware several years ago that Ernie had the desire to eventually adapt one of these Jeep-influenced T5s into his '40 coupe with a blown French flathead, along with it's T-tube and banjo rear end. Ernie's sweet coupe sure would be a "sleeper" in this guise.
Obviously, Ernie had already done quite a bit of engineering and homework on his own. As many of you will note, Flat Ernie has long been recognized on the FordBarn and the HAMB as the "Go-To" T5 guru. As Ernie and Heard noted, this project is certainly much easier to accomplish than it sounds like initially. I'm hoping that this thread has at least encouraged a few to consider this mod on their own cars. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-20-2016, 02:45 PM   #48
Tim Ayers
Dang, how about those apples? Now I just need to scurry up a '33-'34 rear before the prices skyrocket.
Old 10-20-2016, 03:54 PM   #49
Heard
Heard's Avatar
Hmmm.......I just went out there and measured my new shortened torque tube because I wanted to see how close I was to my initial 61 7/8. It is now actually exactly 62" overall.
Please don't use that 62" number though. Make your own measurements. Your results may vary depending upon whose adapters you use as well as other subtle differences.
Old 10-21-2016, 09:16 AM   #50
donald1950
That is really nice... you should sell the kit as it would do a great job.... were i just starting my 41 Pu conversion to T5 i would buy one, rather that do all i did to convert mine to open drive, in a New York Minute.....
donald1950 is offline   Reply With Quote
Old 10-23-2016, 03:14 PM   #51
V8COOPMAN
V8COOPMAN's Avatar
You don't need the whole rear end. Just the torque tube, and maybe the drive shaft from a V8 rear end. Remember, the 4-cylinder parts are 1-1/2" shorter. DD
T5 W/TORQUE TUBE
Old 10-25-2016, 09:04 PM   #52
Flat Ernie
Flat Ernie's Avatar
When I was working on mine a long time ago, I actually acquired a 33/34 torque-tube and driveshaft. My understanding is that it would all bolt up to the later rear, but would need the oil drain hole drilled or aligned...
Unfortunately, a couple of military moves, then a bunch of life got in the way. My old '40 is in storage and hasn't run in a few years. I'm working on getting into a new place here in the new year and hopefully consolidating all my stuff in one spot. Maybe then I can work through my projects and get back to the '40...
T5 Tech
Old 10-27-2016, 05:21 AM   #53
fortyonerag
fortyonerag's Avatar
Great thread. Thanks for sharing all the hard work!
fortyonerag is offline   Reply With Quote
Old 10-28-2016, 06:46 PM   #54
V8COOPMAN
V8COOPMAN's Avatar
Hey Ernie...No doubt the driveshaft would be "close" in length, and could probably have been made to work in Heard's '35 with (at the most) having to make sure the hole for the pin at the rear splines lined-up with hole in pinion shaft. At the most, a new hole would have had to be carefully drilled at the correct spot. As I tried to explain in the thread, the dimension between the snap ring at front, and the hole for the pin at the rear is a critical and exacting measurement. The one difficulty I see with your '40 is that the pinion is six-spline, and the '33/'34 d-shaft is 10-spline, as was Heard's '35. DD
T5 W/TORQUE TUBE
Old 10-30-2016, 03:32 PM   #55
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by expavr View Post
Well thought out and designed!!! My hats off to both of you. There is one question: Looking at the location of the shift tower on the T5 Trans it looks like the shift arm will protrude thru the floor well back into the cab of the truck. How close to the seat did it end up being?
Les Williams
Hey Les.......Heard just put his cab back on the frame so that he could take a couple of measurements and answer your question with accurate info. Pretty slick, huh? DD
T5 W/TORQUE TUBE
Old 11-01-2016, 10:11 PM   #56
Flat Ernie
Flat Ernie's Avatar
Yep...could've been a problem/challenge, but they do make a 10-6 coupler and gearsets are available in either spline...sometimes the later ones had a 10-spline pinion...no telling after 70 years!
T5 Tech
Old 11-02-2016, 02:34 AM   #57
FlatheadTed
FlatheadTed's Avatar
Great job ,Well thought out .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-02-2016, 03:05 PM   #58
JM 35 Sedan
JM 35 Sedan's Avatar
Good job DD and Heard. Wish we had a tech section here for filing these type of threads, but I plan to bookmark this one for future reference.
John
Old 11-02-2016, 03:47 PM   #59
sidevalve8ba
sidevalve8ba's Avatar
Heard,
Keep us clued in on your clutch linkage too if you will. I'd be real interested in seeing that. Thanks.
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 11-02-2016, 04:07 PM   #60
Heard
Heard's Avatar
Ted,
Will do. I'm also working on the parking brake stuff since that has to be sorted out.
Heard
