Old 09-20-2016, 02:01 PM   #1
Ken Arms
Ken Arms's Avatar
Default turn signals
I bought a rather cheap column mounted turn signal unit at a show, just trying to see it work before I permanently wire it up. I bought a 6v flasher but It does not say pos ground. I ran power to the X terminal of flasher, then a direct wire to one front light up to the correct wire of unit for that light. I connected both other flasher wires to there corresponding wires of the unit and I get nothing except a dim glow from the tip of the turn sig lever. Should I be using a pos ground flasher? BTW its a 52 F1 positive ground 6v...confused Ken
Ken Arms is offline   Reply With Quote
Old 09-20-2016, 02:22 PM   #2
adileo
adileo's Avatar
Default Re: turn signals
When I added my turn signals it came with a six volt pos grd signal flasher. So I suspect it's needed. The number on flasher is 535 and Its a thermal flasher, if that helps
adileo is offline   Reply With Quote
Old 09-20-2016, 02:24 PM   #3
JSeery
JSeery's Avatar
Flashers should not require polarity. Are you sure you have it wired up correctly? Did it come with a wiring diagram? They are not a simple just connect it to a few wires type of deal.
Old 09-20-2016, 02:25 PM   #4
D. Jones
D. Jones's Avatar
From my experience when something electrical doesn't make sense "check the ground".
D. Jones is offline   Reply With Quote
Old 09-20-2016, 03:02 PM   #5
Jersey Devil
Jersey Devil's Avatar
Ken
Unit needs to be grounded. If not on the vehicle run a wire from the ground side of the battery or fasten the unit to the steering column.
Hope this helps,
Tom
Jersey Devil is offline   Reply With Quote
Old 09-20-2016, 03:02 PM   #6
DD931
DD931's Avatar
The flasher unit needs at least a minimum amount of current to flash. If there's not enough current, the bi-metallic element won't get hot enough to open the contact. That's why it won't flash when you have a burned-out turn signal light bulb. You need to have a full set of lights in your test circuit. Typical circuits for seven-wire turn signal switches are readily available. Good luck!!
DD931 is offline   Reply With Quote
Old 09-20-2016, 03:23 PM   #7
JSeery
JSeery's Avatar
I can provide a diagram(s) if you need them.
Old 09-20-2016, 04:05 PM   #8
TJ
TJ's Avatar
Those type of units need a good ground to work. It needs to be mounted on the column to make the ground or run a wire to the unit housing from a good ground source. Had the same problem when I mounted it on the column and put a piece of rubber under the clamp so as not to scratch the paint on the column. To cure the problem I soldered a wire to the back side of the housing and ran the wire down with the other wires and put the wire to a good ground on the dash.
Old 09-20-2016, 11:05 PM   #9
Rustyspokes
Rustyspokes's Avatar
Ken.. Google 6 volt turn signal diagrams, is a good start, if you have a number on the signal light flasher unit that's even better I got one at a swap meet for my 34 and followed the diagram and the signals work great, I used separate lamps for the signals , cheers Rus...
Rustyspokes is offline   Reply With Quote
Old 09-21-2016, 10:41 AM   #10
Ken Arms
Ken Arms's Avatar
Thanks all, I got it, I think it was a poor ground at the column. Ken
Old 09-21-2016, 11:35 AM   #11
JSeery
JSeery's Avatar
LOL, like stated always the grounds!
Old 09-21-2016, 11:36 PM   #12
Drbrown
Drbrown's Avatar
Assuming your turn unit has a wiring harness (often 7 wires), the black wire is the ground wire. Grounding on the steering column may not work unless you remove the paint on it.
Drbrown is offline   Reply With Quote
Old 09-22-2016, 03:11 PM   #13
J Witt
J Witt's Avatar
I always run a separate ground wire for these. Usually you can find a convenient ground somewhere under the dash.
This helps prevent a bad ground connection from column contact, and is essential if you don't want to scratch through the paint on the column.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
