Old 09-07-2016, 10:52 AM   #1
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Awwe Crap!
Originally Posted by Capt Kirk View Post
Thanks Mart, I will run home and take some pictures of what I have...I don't believe the attachment points are bolted on but will check. I'm certain it's a broken axle. In neutral with the engine running, there's a slow and steady clink, clink, clink coming from the rear end and when I put my ear on the axle tube, it's clear the noise is coming from within. I can also grab the left rear tire and rock it back and forth with quite a bit of movement...it never did that before.
I mentioned that this will be a driveway project but failed to mention that once the axle is out of the car, I can set up a table in the garage and work on it inside...I just can't fit the whole car in there...sigh!
In neutral with engine running you hear a clink clink clink?? This would not necessarily mean a broken axle to me because the rear gears should not be turning when trans is in neutral. What does the speedometer head do when engine is running, transmission is in gear, and clutch pedal is all the way out, and what type of noise do you hear at the rear then? Keep in mind that noises can travel on the drive train. What noises you think are coming from the rear could actually be coming from the front area of the torque tube (i.e. U joint area), or the transmission, and vice versa.
John
Old 09-07-2016, 10:57 AM   #2
JSeery
JSeery's Avatar
Originally Posted by JM 35 Sedan View Post
In neutral with engine running you hear a clink clink clink?? What does the speedometer head do when engine is running, transmission is in gear, and clutch pedal is all the way out, and what type of noise do you hear at the rear then?
Good catch, why would there be any sounds coming from the rear axle with the transmission in neutral?
Old 09-07-2016, 01:25 PM   #3
Capt Kirk
Capt Kirk's Avatar
With the trans in neutral (and in gear), there is a ticking noise coming from the rear end. I thought it could be that the axle didn't break in a plane perpendicular to the axis of the axle and as the rotating half of the axle came in contact with the stationary half of the axle, it makes a click. Won't a transmission have a "float" rotation in neutral if there's nothing to prevent it from rotating? The clicking sound is similar in neutral and in gear but I didn't want to crawl under a running car with it in gear so I could put my ear to the axle.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 09-07-2016, 01:38 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
You are obviously a WISE man! But..........you could use a long stick (stethoscope) to your ear. DD
Click Links Below __
T5 W/TORQUE TUBE
