#21 |
ZZ any chance we could see a close up of the front and rear end of your torque tube? I'm running torque rods but I like the look of your set up much better. Thanks.
#22 |
Thanks for the kind words flatford. Yes, easier for some maintenance.
#23 |
38bill, Here is a couple of pictures. In the front, I used a large Heim in stead of a tie rod end. Guess either would work. I used a 46-48 front wishbone cut in half for the rear radius rods and torque arm just so they would match. Plus those are about the strongest ones made. Probably overkill on the rear bracket but hey, Safe than sorry I guess.
#24 |
Rules at raceofgentleman.com.
#25 |
Nice pic guys. I know my friend is useing the Model A buggy spring and A rear end with an adapter to use open drive shaft, I know he making torshon bars somehow but I haven't seen it, he lives 85 miles from me. Walt
#26 |
seems for every rule there is an exception: I was helping assemble a '68 Camaro my son-in-law bought in pieces when I noticed the driveshaft yokes were several degrees out of phase. I explained the importance of proper phasing and had him get another driveshaft. It was the same way! He took it to an old time driveshaft shop and they told him there was nothing wrong with it; that's how those Camaros came from the factory. I was working in a Chevy dealer's shop in '67 when Camaro's came out but never noticed this through the years. |
#27 |
FYI
The object of having a negative angle to the drive line is to allow for torque in the drive line. When power is applied the torque will result in the drive line being in a near straight line, and/or a minimal angle, that will allow the u-joints to work properly. If the drive line is installed in a straight line, when power/torque is applied the drive line will torque up causing stress on the u-joints. From my experience, I have found that the subject of drive-line angle is one of the most misunderstood subjects that keep cropping up.
Bill.... 36 5 win cpe |
#28 | |
[QUOTE=40 Deluxe;1348098]
#29 | |
#30 | |
For Oz interest, the tailshaft/driveshaft of an IRS commodore has its yokes not in line . I guess it has to do with the diff centre being fixed and not changing angularly to the gearbox . There must be an engineering reason it is better or they would not do it. |
| Thread Tools | |
| Display Modes | |
