As per original my 1934 RHD sedan locks from the passenger side.
While I understand Henry's reasons for doing this it is some what of a pain to have to lock the drivers door from the inside and exit from the passenger side to lock the car . I was wondering if I swapped door lock mechanisms from a LHD drive car could I then have a locking drivers side door ? Has anyone done this ? -Karl |
Not sure about '34's, but later cars ('37's) had a provision for holding the lock cylinder in the internal door structure.... even though the door skin did not have a hole in it. You could drill the hole in the door skin and then have locks on both doors if you use a LHD lock mechanism.
#3 | |
Super Moderator
To this very day, most states carry this law and still require (by law) that folks exit the vehicle on curb side. Obviously this law is very seldom enforced. However, if one gets the door clipped off when exiting to the traffic side, they will find themselves cited and ruled the cause of the accident.
Karl right up to 1967 [HR Holden ] was the same no external lock on the drivers door
; o 0 . I fitted central locking to my 35 pick up and it solves that problem...
"Came too close to dying to stop living now!" |
I never knew it was a law to exit the curb side.
Now I understand why Barney Fife & sheriff Taylor always did that. Learn sump'n new everyday on these boards. |
#7 | |
Super Moderator
What about getting the necessary internal parts from a RHD car from say, England or Australia? I assume they had locks on the left side, or is this a bad assumption?.....Matt in Alameda
If you lock the drivers door from the inside as you get out, there will be no need to exit from the passengers side. On re entry, you will have to enter the passenger side and slide over. May I see a show of hands who has ever locked themselves out of their car?
He's starting out with a RHD car, which means he wants the lock setup for a LHD car so that he can lock the doors from the driver's side. He already has the original-to-his-car passenger side lock.
#11 | |
. We did wind up punching a hole through the front drivers side window that looked just like a bullet hole, and fished a coat hanger wire down to door handle, pushing it down to the unlocked position.
John, I hate learning things this way....but it is a lesson you never forget!!! In fact, most of my "learnings" came form mistakes like this!!
Dick. |
#13 |
If you do it the way I stated in post #6, you would lock it with the key when exiting just like the pass. side. The inside lock and key lock are separate, independent in the latch.
#14 |
Exactly. What I had determined prior to locking myself out was,....if I pull up on the inside handles on front doors, then closed the door, the mechanism would unlock itself. On the rear doors, if I pulled the handles up, then closed the door the internal mechanism stayed locked. My thought process said if I went in through a rear door and pulled all four door handles up, and closed the back door the car would be completely locked, and that was true. The only problem was I could no longer unlock the passenger side front door using a key. Surprise, surprise. I am sure others have done the same thing, but may not care to admit it here, but I'm hoping that others who read this, will not make the same dumb mistake.
#15 |
In my car if I flick the interior handle forward on the drivers side door to lock it and the try and close it the door unlocks itself -Ksrl
#16 |
While not original, you could buy one of the reproduction outside door handles that have a lock mechanism built into them. My truck has door handle locks on both doors.
Matt 24:36-41 |
#17 |
#18 |
| Thread Tools | |
| Display Modes | |
