Old 07-14-2016, 09:34 PM   #1
RalphM
RalphM's Avatar
Default I think I broke something :(
On my way to a club meeting after work, and pow! Something broke loose, I didn't snap an axle, because it was still driving ok, but boy there's an awful noise coming out of the left rear.
Stay tuned.
RalphM is offline   Reply With Quote
Old 07-14-2016, 09:35 PM   #2
petehoovie
petehoovie's Avatar
Default Re: I think I broke something :(
Did you walk back and look for parts???
Old 07-14-2016, 10:58 PM   #3
RalphM
RalphM's Avatar
No, I think thier still rattling around in the brake drum. I'm thinking either I sheared an axle key, or the brake shoe return spring broke, or part of the e-brake hardware?
First problem I have is how to get the hubcap off without bending the trim ring.
Old 07-14-2016, 11:23 PM   #4
outlaw
Damn young hot rodders! How many feet of rubber did you lay down?
outlaw is offline   Reply With Quote
Old 07-14-2016, 11:26 PM   #5
RalphM
RalphM's Avatar
Actually I was getting on the highway, may have put my foot into it abit too much, nah. I was doing about 60 when it let go.
First thought I had was broken axle.
Old 07-14-2016, 11:29 PM   #6
outlaw
Ralph, I hope that it is not hurt too bad & is a easy fix. Bill
Old 07-14-2016, 11:55 PM   #7
RalphM
RalphM's Avatar
Me too! But in case of emergencies I have two spare rear axles.
Old 07-15-2016, 12:28 AM   #8
deuce_roadster
deuce_roadster's Avatar
If you are driving the hub with the axle key, the hub isn't tight enough. The surface area of the taper on the axle and inside the hub gives enough friction to propel the car with no pressure on the key at all when everything is up to spec. This topic isn't new here.
I would be VERY suspicious of the axle if you did shear off a key. That is how a crack begins at the inner end of the key groove. I would have it magnafluxed or die penetrant check done before I trusted it. That is IF you did shear a key.
Old 07-15-2016, 03:33 AM   #9
my4dv8
We were on a 6 day run and on the last 3 hrs from home we had a horrendous noise from the rt rear. Found very unhelpful garages they didn't want to know . Jacked it up and pulled the drum ( oh we got the drum off easy as we had fitted F100 slide in axles 3 years before) and found the handbrake cable clip had somehow come off and cable end was rubbing on the drum magnifying the noise. So wow that was an easy fix but the noisy was LOUD.
my4dv8 is offline   Reply With Quote
Old 07-15-2016, 10:04 PM   #10
paul2748
paul2748's Avatar
Go on ebay and get set of those nylon? pry tools. They work very nice and no scratches.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-15-2016, 10:51 PM   #11
TonyM
TonyM's Avatar
A vintage Ford tire iron, used correctly, will not damage the trim ring.
TonyM is offline   Reply With Quote
Old 07-15-2016, 10:52 PM   #12
RalphM
RalphM's Avatar
Well, for all that noise it wasn't so bad. The ebrake lever pin clip fell off and the pieces were rolling around in there. New PRC parts!
I'll look for some old originals.
The brake springs I'm using are original as I couldn't get the darn repops to go on there.
Old 07-15-2016, 10:56 PM   #13
RalphM
RalphM's Avatar
My solution for the hubcap, a pair of Diesel engine injector removal bars.
Old 07-15-2016, 11:02 PM   #14
outlaw
Ralph, Glad that it wasn't anything major. It won't take anytime to get it back on the road.
Old 07-15-2016, 11:14 PM   #15
FordCustom
You want to know the sad part. The drum brakes on the 98 Ford truck in the driveway, stlll use those exact clips.
FordCustom is offline   Reply With Quote
Old 07-16-2016, 01:23 AM   #16
mike42
mike42's Avatar
Take the trim rings off first before the hub cap.
mike42 is offline   Reply With Quote
Old 07-16-2016, 10:33 AM   #17
RalphM
RalphM's Avatar
I would have, but was worried about bending them as well, thier in pretty tight.
Plus I've seen wheels that the trim rings have been on and off multiple times,
They are all gouged up. These are powder coated, but I think it would still eat them up.
Old 07-16-2016, 10:40 AM   #18
JSeery
JSeery's Avatar
You should be able to get the clips at about any autoparts store. Need to be sure that they are on good and crumped down properly.
Old 07-16-2016, 11:16 AM   #19
APDAVE
Don't pry on the outside edge of the trim ring, pry on inside they will come of with out damage.
APDAVE is offline   Reply With Quote
Old 07-16-2016, 11:23 AM   #20
scrapiron
I've had a pair of them for almost 50 years, used for everything but diesel work,,,,a great every now & then tool.
scrapiron is offline   Reply With Quote
