Old 12-25-2010, 08:03 AM   #20
40Pickup
40Pickup's Avatar
Default Re: Mitchell overdrive
Originally Posted by Mart View Post
I, too, would be VERY interested in the details of this conversion - I have all the parts laid out in my garage and am about to try and make one myself.
I must say your conversion looks first class and would appear to be a neat and efficient unit.
Do you have any pictures of: = For the most part, I take photos while on what I do, but unfortunately not this time.
But I shall attempt to come back with some drawings that would clarify.
The adaption of the torque tube to the front of the unit?
The adaption of the driveshaft to the front of the unit?
Mods to the tailshaft housing?
The final driveshaft from the unit to the diff pinion.
Some questions..
Was any resplining involved? = No
The positioning of the unit near the rear end of the torque tube - is there an advantage to this, or could the unit be fitted almost anywhere along the length? = If I understand correctly, you should keep the unsprung weight as low as possible and therefore the O / D when mounted as far forward as possible, while you have to take into account whether there is sufficient space.
Is the lubrication of the unit self contained or shared with the axle? = Self contained (ATF).
I envisage mine being a home brew job with lots of welded up shafts and parts, with the od unit towards the front of the shaft.
To be able to see details of one already made up would be a great advantage.
Thanks in advance, hope you can help.
Merry Christmas.
Mart.
Mart, hope this can help a bit, see the text above.
/ 40Pickup
40Pickup is offline   Reply With Quote
