#21 | |
My exhaust mods are more to create a less turbulent environment thereby reducing the chance for creating hot spots in the flow "eddys" that now exist in the end exhaust ports. |
#22 |
I seem to remember the Motor City Flatheads project was at one time predicting they would run about $12K or somesuch.....
#23 |
#24 |
That may be for a complete engine assembly or at least somewhere near complete. Many of the changes made require the use of their proprietary parts.
#25 |
For reference, the aluminum 348/409 blocks that are now available from the aftermarket are $5k+. That's also from a manufacturer (World Products / Bill Mitchell Products) that specializes in aluminum engine blocks and heads.
Granted that market would probably have a bit smaller audience at this current time, but original 348/409 blocks are much more scarce and expensive than their Flathead counterparts, which I think would make the demand similar (or perhaps even greater) for a brand new block. An aluminum Flathead block would have to be quite a bit cheaper to garner sales.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
#26 |
#27 |
why not just repro the ardun set up .
#28 |
Oui, oui!! That's all I can remember.
#29 |
The french block patterns may not be the way to go. Check this thread on the H.A.M.B :
http://www.jalopyjournal.com/forum/t...#post-11572493 |
#30 |
The New RoushYates Aluminum block closely copied from the cast (kinda) Nascar block is $6500-7000 . I certainly can not see how you could design , cast & machine an Aluminum flathead block for even close to that ! But I am all in for 1 new aluminum fully machined , tested useable block @$3000 ! But my offer ends in 3 years !
Cheers Tony |
#31 |
I could see myself spending $2500.00 on a new fully machined block but not much more.
There is just too many good used blocks still available to warrant spending much more. Basically there just is not enough demand to make casting a new "replacement" block a fruitful venture. |
#32 | |
I wonder if an aluminum block engineered and machined here but cast overseas might be a little more palatable. I honestly believe that the sleeving process could be eliminated and the PTAW process could be employed more ecomically and with less trouble than designing a sleeved (wet or dry) engine. In addition the PTAW system would allow for a bigger bore from the get go with a higher quality cylinder surface to boot. It really is an amazing technology that promises to revolutionize engine design and or refurbishing. Is there ever any chit chat around the Roush garages about the Flathead Ford knowing that Jack is a huge fan of these old cars? Maybe he'd be the guy to talk to, to get the ball rolling. Or at least to get this pointed in the right direction. |
#33 | |
Do you suppose a block such as the one we are talking about could spawn the era of the $6500 Flathead crate engine that can entertain you with 200-225 hp and 275- 300 ft/lbs of torque? |
#34 | |
complete rotating assembly (scat) 1800.00, cam lifters valve train 1000.00 oil pump 200.00, so yes I would say you could get a short block less heads and intake/carbs for 6500. provided the block could be produced for 3k
#35 | |
#36 | |
#37 |
Ok, dumb question time. Isn't one of the first things done to a flathead relieving the block to improve flow and isn't relieving considered the most bang for your buck in terms of performance? How is that going to work with iron cylinders and aluminum deck? Just a logistical question.
Oh, and block ready to assemble? Nothing else? $2500 if I was feeling nostalgic. As far as performance numbers, at this point I would build a stroker 302 for that price and be done with it. |
#38 |
"aonemarine", The kind of power we're talking here will surely cause problems (I know, I had a '36 3-window with a healthy 276" Merc). I am done with the part of my life where I enjoy fixing pre-49 Ford driveline boo-boos. A standard "traditional" hop up (heads, carbs, and a little cam) makng 125 HP, sure, but not at this power level.
"Diavolo", I believe current thinking is that relieving is of little value on any but the most highly modified engines. Last edited by tubman; 06-28-2016 at 08:33 PM. |
#39 |
Well guys I built a 265" Flatty for my friend with a Max 1 cam. Careful porting no relief. It is backed by a T5 trans and runs a single 94 carb. It resides in a Model A Coupe with full fenders. It is a gas to ride in or drive.
The thing is the T5 and or the C4 automatic are becoming a popular way to get the most out of our dear Flatheads. It is simply an option that many builders are taking these days and they work well. |
#40 | |
| Thread Tools | |
| Display Modes | |
