Old 06-07-2016, 01:00 PM   #1
30-9
Default How hot is too hot
I know these flatty's like to run on warm/hot side. In traffic I see my temp hitting 190. Which I believe. Is ok. But at what point or temp should I say time to pull over and wait for cool down?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 06-07-2016, 01:16 PM   #2
Tinker
Tinker's Avatar
Default Re: How hot is too hot
190 is great in traffic, as far as I'm concerned.
200-210 is getting real hot. Thing is, once you shut down it'll go up another 10 degrees without the pumps moving water.
Just my thoughts.
Old 06-07-2016, 01:22 PM   #3
4dFord/SC
4dFord/SC's Avatar
The manual says as long as it's not boiling.
4dFord/SC is offline   Reply With Quote
Old 06-07-2016, 02:34 PM   #4
Tinker
Tinker's Avatar
Roughly...
Water boils @ 212
Antifreeze @ 265
265 degrees sounds a little high
Old 06-07-2016, 02:52 PM   #5
VeryTangled
VeryTangled's Avatar
Hi Everyone, Tinker, remember that 265 degree number includes a 15psi pressure cap. Unpressurized it's about 223. Add 3psi per one pound of pressure.
-Jeff H
Old 06-07-2016, 03:09 PM   #6
Tinker
Tinker's Avatar
Very true Jeff.
Some more discussion on flathead temperature ...
http://www.fordbarn.com/forum/showth...3954&showall=1
Old 06-07-2016, 07:42 PM   #7
30-9
Ok so if I'm reading this right, at 210 I should pull over and open hood. Logic is 210 + 10 rise after shut off = 220 danger zone - as my cars are no pressure caps.
That right?
Thanks - 30-9
1939, 1940
Old 06-07-2016, 07:57 PM   #8
roundvalley
roundvalley's Avatar
Start by checking your gauge to be correct. Use a thermal gun to verify the gauge and go from there. I have seen lots of gauges to read much higher than true Temp.
roundvalley is offline   Reply With Quote
Old 06-07-2016, 08:39 PM   #9
Old Henry
Old Henry's Avatar
Originally Posted by Tinker View Post
Very true Jeff.
I just re-read that one again. It's a true classic on the subject.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
