Old 12-14-2014, 04:39 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Here's Pictures of the Model A Fuel Filters
The first is the pencil filter, which never came on a Model A, but I would always use one, even on my very clean tank. The second one shows the filter inside the cast iron sediment bowl. Of course it shouldn't be bent out of shape like this one. These are often missing or destroyed by water and corrosion.
The third picture shows the fine screen inside the carburetor, and these are often in very bad shape or plugged also.
BTW, I took these pictures of that great cutaway running gear at the Model A museum at the Gilmore Car Museum in Hickory Corners, Michigan.
Old 12-14-2014, 04:55 PM   #2
mshmodela
mshmodela's Avatar
Default Re: Here's Pictures of the Model A Fuel Filters
Tom, great photos. Thanks for the post.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 12-14-2014, 05:03 PM   #3
Great Lakes Greg
Great Lakes Greg's Avatar
That cut away car is pretty cool. It may have had the biggest audience of anything in there when we visited on Model A day.
Great Lakes Greg is offline   Reply With Quote
Old 12-14-2014, 07:12 PM   #4
Tom Wesenberg
I forgot to mention, look at the fuel flow through the cast iron sediment bulb filter. It's the only filter I know of that filters from the inside to the outside.
Old 12-14-2014, 09:02 PM   #5
DougVieyra
DougVieyra's Avatar
Okay, now I have to go to the garage and tear apart my cast iron sediment bowl, to see if it has the screened internal filter. And if so - is it bent. Thanks Tom, for all your help in getting us to better understand our beloved (on the 'good days') Ford Model A.
DougVieyra is offline   Reply With Quote
Old 12-14-2014, 09:16 PM   #6
Gooseloony
Gooseloony's Avatar
Tom that's great info. I just received my pencil filter, can you recommend an install method, any special tools, fittings, sealing etc? With photos if possible. Thank you
Gooseloony is offline   Reply With Quote
Old 12-15-2014, 01:13 PM   #7
Tom Wesenberg
Most of the pencil filters fit fine by just slipping them into the valve. Years ago I had to use solder to tin the end for a tighter fit.
When you unscrew the valve you may find it very tight. Try to use two wrenches or at least use your hand on the valve to push as you pull with the wrench with you other hand. You're trying to use turning torque, rather than a side pull, to unscrew it.
Old 05-24-2016, 07:18 AM   #8
ltdann
ltdann's Avatar
I just bought an original cast iron sediment bulb. Turns out the filter element is too long to fit in the bulb. It looks as if the seat at the top of the bowl has been crimped or something. I think I'll Dremel the bottom of the screen element to get it to fit in the bulb. Anyone have any thoughts here?
Rich
ltdann is offline   Reply With Quote
Old 05-24-2016, 07:28 AM   #9
Keith True
Keith True's Avatar
Rich,take a good close look at that crimped piece.It may be a piece of an old screen that was stuck and got the screen part torn off of it in the past.Over the years there were a lot of aftermarket screens made that were built nothing like the originals.
Keith True is online now   Reply With Quote
Old 05-24-2016, 07:33 AM   #10
ltdann
ltdann's Avatar
I will take a look. It certainly looks like that may be the case since it isn't part of the casting. I'll just pry that sucker out of there
Rich
Old 05-24-2016, 07:33 AM   #11
DANA BIZZELL
DANA BIZZELL's Avatar
Tom, which supplier do you think sales the best shut off valve.
Thanks
Dana
DANA BIZZELL is offline   Reply With Quote
Old 05-24-2016, 09:12 AM   #12
Tom Wesenberg
Thanks
Dana
My first guess would be that they might all sell the same filter.
I think Keith is right about there being part of the old filter stuck in the bowl. I find the same thing happens with the small brass filter in the carb inlet.
A lot of cast iron bowls need to be sandblasted to get rid of the rust.
Old 05-24-2016, 10:27 AM   #13
RockHillWill
RockHillWill's Avatar
Nice work, Tom.
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 05-24-2016, 10:39 AM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
LOVE that cutaway car ! In the '50's, in auto shop, we did a cutaway of a Plymouth engine, took FOREVER! We used an arc welder to cut away some of the cast iron parts.
Bill Slice
"THE ASSISTANT GURU OF STUFF"
Old 05-24-2016, 11:17 AM   #15
supergnat
supergnat's Avatar
The cast iron sediment bowl filter (not original) on my 28 works great. It even filters powdered rust that the pencil filter in the tank didn't catch.
Supergnat
supergnat is offline   Reply With Quote
Old 05-24-2016, 05:59 PM   #16
DANA BIZZELL
shut off valve under tank not filter.
thanks
Dana
Old 05-24-2016, 06:54 PM   #17
supergnat
supergnat's Avatar
The pencil filter I was referring to is the one in Tom's first photo which mounts on the tank side of the valve. I know it is not original but it really helps if one has a rusty tank like I have.
Old 05-24-2016, 07:06 PM   #18
ltdann
ltdann's Avatar
I spent the evening trying to remove the brass insert that makes up the top part of the filter. So far, all I have managed to do is destroy that piece, but I still haven't been able to get it out. Any suggestions?
Rich
Old 05-24-2016, 07:18 PM   #19
supergnat
supergnat's Avatar
I would try soaking it in carburetor cleaner over night to see if will come loose then. If you have access to a small ultrasonic cleaner try putting it in that for awhile with solvent. That might break-up what ever is holding it in the valve. That's how I cleared the vents on an original gas cap.
Supergnat
Old 05-24-2016, 07:19 PM   #20
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Tom,
Thank you for sharing your pictures.
Some thoughts on replacement shut off and filter:
1). I only recommend the USA made replacement shut off (or rebuild your original).
2). Some of the early replacement did not last very long. Those shutoffs are identifiable, in that they had a seam in them.
3). I replaced a shut off valve once, that did not have a pencil filter, but it did have a short pipe, which kept any rust debris on the bottom of the tank from entering the shut off.
4). I usually put some gas resistance sealer on the threads, before installing the valve. Be careful not to get any sealer on the filter screen.
Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
