Old 04-30-2016, 12:36 PM   #1
Ten1nis
Ten1nis's Avatar
Default CLutch Chatter
My '28 Sport Coupe with a standard clutch plate and flywheel experiences clutch chatter when I go forward or reverse from a standing start. What is the possible cause(s) of this? Thanks.
Ten1nis is offline   Reply With Quote
Old 04-30-2016, 12:40 PM   #2
Dollar Bill
Dollar Bill's Avatar
Default Re: CLutch Chatter
Oil contamination of the clutch disk is one possible cause.
Did this just begin or is the car new to you?
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 04-30-2016, 12:47 PM   #3
hardtimes
hardtimes's Avatar
X2, what Dollar Bill says !
This most likely can be confirem with more info, i.e.-like is equipment 'original'; have you had an oil leak/drip/running from bottom of bell housing cotter hole; do you have grease 'zerk' on trans shaft collar..and othergreased it ?
If you have NEw equipment/rebuilt lately...adjustment of linkage and/or pressure plate out of adj specs.
Old 04-30-2016, 01:59 PM   #4
Brianfrench65
Brianfrench65's Avatar
I had serious clutch chatter, and it turned out to be a seriously out of tolerance pressure plate .045) out.
Changed the clutch plate and the pressure plate. Then I have smooth sailing.
Brian French; 1930 Briggs Town Sedan
Brianfrench65 is offline   Reply With Quote
Old 04-30-2016, 05:26 PM   #5
Fred K-OR
Fred K-OR's Avatar
I have clutch chatter on my huckster. To help getting started, I will sometime put the spark lever all the way up and that seems to cut down on the chatter. This may help you till you find out what to do from hers.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 04-30-2016, 07:01 PM   #6
WestCoast
oil on clutch and fly wheel, badly worn piolet bearing, warped pressure plate, an old clutch with out the marcel, the wavey metal plate between the clutch faces, a clutch with out the spring hub in the clutch disk, bad motor and trans mounts worn bushing on the rear end
WestCoast is offline   Reply With Quote
Old 05-01-2016, 10:39 AM   #7
Ten1nis
Ten1nis's Avatar
Smile Re: CLutch Chatter
Thanks for all your ideas. Looks like I'll be busy with mechanical stuff!
Old 05-01-2016, 12:02 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Minerva chattered! For a month, I took off only in second (no chatter) & after that, she was smooth as SILK!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-01-2016, 01:32 PM   #9
Art Newland
Art Newland's Avatar
Might be the way you drive it too, don't rev up and slip the clutch like a modern car.
Art Newland is offline   Reply With Quote
Old 05-02-2016, 10:05 AM   #10
Patrick L.
Patrick L.'s Avatar
If you see oil on the clutch while looking thru the inspection plate then that may be the cause.
Usually the problem is,
out of spec tolerance clutch cover
slightly warped flywheel
out of spec adjustment pressure plate fingers
Old 05-02-2016, 04:06 PM   #11
Bob/Kansas City
Bob/Kansas City's Avatar
If you have oil on the clutch disc and flywheel there's a cheater fix to temporarily reduce or stop the chatter. Take the floor boards out and remover the inspection cover on the clutch housing. Then with the engine running, trans in neutral and park brake on push the clutch pedal to the floor and spray Brake Kleen between the disengaged clutch and the fly wheel. Spray heavily until it starts dripping out the radius rod socket on the bottom of the trans.
The clutch will be spinning so it might get messy but if oil on the clutch is the problem this should give you some temporary relief from the chatter.
If this doesn't help then you may have other problems that need to be diagnosed.
Bob/Kansas City is offline   Reply With Quote
Old 05-04-2016, 08:30 AM   #12
Dollar Bill
You don't have Float A Motor engine mounts do you?
