Old 02-08-2016, 09:36 AM   #1
flathead47
flathead47's Avatar
Default 36 glove box
I'm working on my project 36 dash & the glove box door is stuck slightly open. I have removed it from the dash & trying to free it up. It appears the ends of the round hinge bar attached to the door are fixed & should not move. Is the hinge bar a complete assembly that goes thru the dash mounting bracket as one unit or are there 2 separate pieces that slide into each end of the dash mounting bracket. It is a hard assembly to find so do not want to destroy the hinge assembly , just want to free it up.
flathead47 is offline   Reply With Quote
Old 02-08-2016, 10:19 AM   #2
Willit Stop
Willit Stop's Avatar
Default Re: 36 glove box
My '36 had the same problem.Squirt some penetrating oil on the moving parts and work them back and forth.It should free everything up. One of my flat springs broke. It still closes nicely and completely with one spring.
Willit Stop is offline   Reply With Quote
Old 02-08-2016, 11:11 AM   #3
flathead47
flathead47's Avatar
thanks willit stop .... I put penetrating oil on hinge , will just have to let it work.
I only have one spring in the center , early ford book states only roadster & phatons had one in center like mine , looks like it has been like that for a long time , all the rest should have two , I wonder if early 35 only had one & this got put on my dash.
Old 02-08-2016, 06:27 PM   #4
mrtexas
mrtexas's Avatar
Soak in evaporust. The hinge wire is rusted to the door. It fixed mine.
mrtexas is offline   Reply With Quote
Old 02-09-2016, 07:26 AM   #5
Kerk
Try some KROIL and maybe a little heat + time and keep working what little it does move. Worked for me. kx
Kerk is offline   Reply With Quote
Old 02-09-2016, 04:13 PM   #6
Ken Bull
Ken Bull's Avatar
I put my hinge in a vise and soaked with WD40 and moved it back and forth several Xs. Its been fine for 5 years.
Ken Bull is offline   Reply With Quote
Old 02-12-2016, 08:23 PM   #7
flathead47
flathead47's Avatar
Patience , some Barnes Distribution BD 7-77 penitrant & I was able to get the hinge free. Thanks for all your replies , another part saved.
