I'm a little confused about a 5 window coupe, business coupe, (plain old) coupe and sedan coupe for year 1948.
I assume what is referred to a 5 window coupe would be the business coupe, maybe and Super Deluxe Sedan Coupe would be the longer top coupe? The reason I ask is on the La Barron-Bonney site they ask for the model as in sedan coupe or 5 window coupe. Jeez I'm mixed up! Could someone set me straight on this? Thanks.
Nothing wrong with it except for the name on the front. Alex |
I would suggest that you contact La Barron-Bonney and get the definition from them. That way there will be no guessing or getting the wrong kit.
Imagination is more important than knowledge. |
There are two different coupe bodies...the sedan coupe type uses the wide door from the tudor and has a longer roof allowing a decent back seat. The other type uses the narrow door from the fordor and has a shorter roof that drops down more quickly than the other. Obviously all side panels and headliner are different, for starters.
Good Vic. You're right.
Thanks.
#5 | |
I always heard that if it's a business coupe it has the short doors.
The sign of a good craftsman is how well they cover up their mistakes. |
I don't believe LeBarron Bonney recognizes the "business coupe" moniker for the 41-48 series preferring "standard coupe". At least that was my experience with them.
Some call it a club coupe but correct name is Sedan Coupe actually I think the name is really a coupe sedan
I believe short door or long door would be the best all around description.
That should avoid any confusion. Bruce
Works good Lasts long time |
Thats what I have always referred to them as.
Matt 24:36-41 |
| Thread Tools | |
| Display Modes | |
