Old 11-19-2010, 09:39 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default 39-42 heads
Do all those early 24 stud heads 39-42 have the same cc chambers? I know the A heads really pump up the compression on the 239 engine. I know you have to do a little cutting in the top of the valve pocket to use them on the 59 engine. I know the 40-41 heads have an A in the center, I don't think the 39 head do. Is that correct? Thanks Walt
Old 11-19-2010, 09:51 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: 39-42 heads
I thiink that the dome is a different shape for the 3 1/16'' pistons, the center leaves a big gap on the top of the 3 5/16'' piston... I looked to use a set on an engine I am building now, did not like the taller dome... Karl
Karl Wolf is offline   Reply With Quote
Old 11-19-2010, 10:36 PM   #3
flatjack9
flatjack9's Avatar
39 heads have the A.
Old 11-19-2010, 10:55 PM   #4
Fe26
There has been a chart posted over on the HAMB giving a lot of info about head chamber capacity. The short answer to your question is no. Chamber capacity varies quite a bit.
Fe26 is offline   Reply With Quote
Old 11-20-2010, 08:27 AM   #5
David W Juliano
late 1938 - 1941 used the same heads: 81A-6049-A and 81A-6050-A with an "A" in the center of the head.
David W Juliano is offline   Reply With Quote
Old 11-20-2010, 08:54 AM   #6
JWL
According to the Ford Service Bulletins there is very little difference between any of the 24 stud, iron heads with the exception of the "T" heads. The best of the Ford iron heads, older than 1948 are the 59A-"B" heads. The 81A heads are listed as 77-79cc. The 29A is listed as 78-80cc. The 59A-A head is 77-79cc and finally, the 59A-B head is 73.5-75.5cc.
The dome contour radius spec is the same in the "A" head as the 59A head. The differences are in the pistons. I have seen 4 different piston domes and would not be surprised if there are several more. None are a perfect match for the Ford design. Too, each aftermarket head manufacturer applies a different dome contour. About the only way to blueprint is to make a cutter which matches the chosen pistons and re-cut the heads. For performance and efficiency it is more important to have the piston to head clearance as tight as possible at the outside of each bank. For that reason I usually angle mill heads, ream the stud holes and reface the washer spotfaces on aftermarket heads.
JWL is offline   Reply With Quote
Old 11-20-2010, 09:59 AM   #7
Walt Dupont--Me.
Thanks guys for the info. Walt
