Les Andrews Books have been out for a few LONG years now. There have been reported of a few to many mistakes within each of the three volumns.
There have been reports to "throw the book away"...NO WAY...These books are to valuable of an asset to the Model A community...This is not my intention...My intention is that there is a lot of complaining about them because of mistakes...OK THEN...lets list them and get Les's opinion on them and settle this once and for all so the newbies coming into the hobby won't, for a better word, screw up on their intitial restoration. If this is the case, then I will start a thread concerning these mistakes and let's see just how many of us respond and let's see if Les can comment on them and issue out an eratta sheet correcting the errors. Some of you have made lists of them...let's see them. You are right, nothing will get done about this issue if we as a group don't step up to the plate and do something about it...complaining is not going to get us anywhere. So with that, let's step up to the plate, quit complaining, and post your found error or errors if any at all and quit complaining. Anybody????? I will run this for a week...you know..."bttt" (back to the top)...and see just where it get's us. Pluck Last edited by Steve Plucker; 08-24-2015 at 06:25 PM. |
The Oil Pan Torque says 20 Ft LBS!
20 inch pounds maybe at best is more realistic. I prefer to tighten just snug. One handed with short ratchet.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
Good idea. I hope this thread gets a lot of responses.
We will see...A lot of guys are really afarid to say anything at all and will not comment for fear that someone else will rag on them. That is not what this thread, I hope, is about...It is about the bonified errors within his books that some have complained about over the past few years.
One down...How many more? Pluck Last edited by Steve Plucker; 08-24-2015 at 04:27 PM. |
Don' have the book handy, it's out in the shop, but there's the oft quoted one about the wrong torque on the oil pan bolts. IIRC Les says 20 ft-lbs and I understand that it should be 20 in-lbs.
There are a couple of things in the book that I questioned, I just can't remember what they are right now... ![]()
Cutting off the motor mount at the angle and only using the section for the frame. I know that some of the repops are/were too thick in that area, but they can still be used without cutting them off. Better choice would be to buy the repop that is made close to the correct thickness. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
#8 | |
Two down... Pluck |
i dont have the book in front of me right now but wasnt there a discrepancy about the lengths of the brake rods?
Would it help to mention the page the error is on also?
Steering sector shaft size is wrong.
The number has moved over in to the Bratton's catalog. I think the biggest weakness of his book is a lack of dimensions. For example, determining the fit of a tranny gear to the spline shaft. As I recall he states put some oil on the shaft and let it slide down. If it goes down fast then it is worn too much. I had a shaft and a gear where it went down fast but it only had about .001 or .002" of wear total when measured. I know there were some other things. I started writing details as I found them at one point. The problem is I do not need to reference the book much these days. I have other sources. His illustrations are wonderful and it is absolutely a must have for your library, but as with all the books you need to check the numbers. |
#12 | |
Pluck |
#13 |
#14 | |
Pluck |
#15 |
Steve,
Les's book has really helped me in working on my Model A and others in our club as has this forum. I have tried to follow the cotter pin usage chart in Appendix A-3 and I think the Front Brake Plate Assembly should take 8 cotter pins(4 each side) even though my copy of the book says 3. I am so glad Les took the time to make this manual for guys like me. Jerry |
#16 |
I will... when I recall WHAT they were...
#17 |
This thread can be very useful, but if you post an error include the Title of the Manual, and which printing the error is in and the page.
Les Andrews has published the following manuals: Model A Ford Mechanics Manual Volume 1 Model A Ford Mechanics Manual Volume 2 Model A Ford Trouble Shooting and Diagnostics The Service Bulletin for April 1928 page 239 notes the toe in should be set at 3/16" to 1/4" and was changed in the Service Bulletin for Sept 1928 page 282 to 1/16" + or - 1/32". I have a First printing Model A Ford Mechanics Manual Volume 1 and on page 2-19 the toe in is noted at 3/16 + or - 1/16. I also have a 2nd printing Model A Ford Mechanics Manual Volume 1 and on page 2-19 the toe in is noted 1/16 + or - 1/32 which is correct per the Service bulletins for Sept 1928 page 282.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 08-24-2015 at 03:13 PM. Reason: added titles for the three Les Andrews Manuals |
#18 |
Jerry, I do not take this as a chance to beat up on the book or Les personally. Almost every technical book has an error or two, most way more than two. Even the Crown and Barrett books I use every day there are errors and as they are found by someone and reported to the companies we get updates to our manuals. Even I have found errors and reported them and they went up the chain and were corrected. Info is forever changing that is one thing that is constant. We received a shipment of 15 new forklifts last week and although they are the same as the 5 we received last year we have encountered new problems over the weekend. I am sure new info will be generated from whatever we find the problem to be. So far it is eluding us. Rod
#19 |
Les Andrews has written the most comprehensive and definitive book ever written about the Model A Ford. His mechanics handbook has aided many Model A enthusiasts. The few errors in the book that I have noticed are so minor that they will not lead anyone down the wrong path. There are some areas where he could have provided more detail. This is where others can contribute, rather than detract. Rather than pick Les’ work apart, time could be better spent writing technical articles that compliment and add more information to his articles.
Tom Endy |
#20 |
Well said, Tom.
I think it's a bad idea to critique Les' books. There are sections that are purposely left a little ambiguous because there are things that are just common sense. I find many areas in the book that are well detailed. Larry |
| Thread Tools | |
| Display Modes | |
