Old 08-02-2015, 05:35 PM   #1
V12Bill
V12Bill's Avatar
Default Pig in a poke
About 2 weeks ago I purchased a 1934 and a 1938 - 1940 engines along with some odds and ends parts. The 1934 engine " had run good when pulled" and no comment on the other engine. I got these engines home and noticed that the 1934 engine was missing half the teeth from the fiber timing gear. So much for "run good when pulled" At least I knew why the engine was pulled, at least not a rod that had let go. The heads were 68-**** and the pan had the crankcase vent in it, but these things could be changed. I soaked the engine in diesel fuel and after a few days the crank turned over. I pulled the pan and lo and behold the main studs were on 3 1/4 " centers. Yes it had inserts and was an LB engine without the LB stamped on the intake surface of the block. Some days even a blind squirrel finds an acorn!! I checked for cracks on the intake holes and found none. When I get the block stripped I'll get it boiled and magnafluxed. Keeping my fingers crossed.
V12Bill is offline   Reply With Quote
Old 08-02-2015, 06:16 PM   #2
Fe26
Default Re: Pig in a poke
Lucky-lucky you.
Fe26 is offline   Reply With Quote
Old 08-02-2015, 08:15 PM   #3
Shadetree
Shadetree's Avatar
You are vey fortunate, the LB's are hard to find.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 08-02-2015, 08:40 PM   #4
Charlie ny
Bill,
Congrats on the LB score. Try to get a sonic check on wall thickness. I
lost an LB due to core shift.
Charlie ny
Old 08-04-2015, 05:20 AM   #5
RobR'35
RobR'35's Avatar
I don't mean to cut in but curious of the core shift thing.
Im real new to the V8. With the core shifted to the extreme that it couldn't be sleeved?
RobR'35 is offline   Reply With Quote
Old 08-04-2015, 10:31 AM   #6
JSeery
JSeery's Avatar
I was of the belief you can sleeve almost anything. There are different types of sleeves.
