Old 07-23-2015, 08:03 AM   #5
36tbird
Default Re: Aluminum head anti seize
I cannot state that this works because I have not had to remove a head, but it is what I've done with my heads, cast iron and aluminum, on two engines.
http://www.stefs.com/bandb/products/...washerstep.htm
To me it is intuitive, if you keep the bolts or studs centered in their holes, then there should be little corrosion or electrolysis that impairs head removal. I also used anti-seize on the shanks as added insurance. Be aware, you have to buy a special bit to drill the heads to accept the washers.
36tbird is offline   Reply With Quote
