Old 07-18-2015, 06:00 PM   #1
corvette8n
corvette8n's Avatar
Default Flathead oil tempeture
What would be a normal oil tempeture for a stock 8BA flathead.
Old 07-18-2015, 07:27 PM   #2
Ronnie
Ronnie's Avatar
Default Re: Flathead oil tempeture
This is going to be a controversial thread.
Just waiting in the wings for the dispute to begin."LOL"
The oil will usually be 10 to 15 degrees hotter than the coolant.
R
Ronnie is offline   Reply With Quote
Old 07-18-2015, 11:02 PM   #3
Fordestes
15 degrees above normal cooling system temp is good! depending on ambient conditions, helps oil flow and less drag, lessens oil contamination from moisture retention etc. Ol'Henry, The oil contacts the hottest parts of the engine directly and carries away heat from these parts and retains what heat that is not extracted from it by the engine castings of which are cooled by the cooling system and ambient temps such as air circulation around the external portion of the engine oil pan etc., sometimes an external oil cooling device is necessary to stabilize oil temps depending on the application and demands placed on the engine.
Fordestes is offline   Reply With Quote
Old 07-18-2015, 11:22 PM   #4
JSeery
JSeery's Avatar
One of the reasons Ford went to a pressurized cooling system was to help increase the oil temperature. Hotter oil is better for several reasons.
Old 07-18-2015, 11:56 PM   #5
Kahuna
Kahuna's Avatar
I have an oil temp gauge on my flathead, along with 2 coolant temp gauges (1 for each head).
The oil temp never gets near the engine temperature.
Even on a hot day 95+, oil temp remains below 160 degrees, while engine temp may be at 195.
Kahuna is offline   Reply With Quote
Old 07-19-2015, 04:08 AM   #6
V8 Bob
V8 Bob's Avatar
X2. I have a similar setup on my '32 and the oil temp always stays below the water temps.
Old 07-19-2015, 04:18 AM   #7
48 coupe
48 coupe's Avatar
It all depends on how hard the engine is working. The oil need to get past 212 some time to burn out the water and gas. It can idle for a week and never get the oil hot .220 or so.
48 coupe is offline   Reply With Quote
Old 07-19-2015, 11:02 AM   #8
Ross F-1
Ross F-1's Avatar
Water and gas will evaporate long before 212.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-19-2015, 02:13 PM   #9
JonC
On my new Corvette (is that banned I didn't say that chev... word) the oil temp reading is below water temp by at least 15 degrees.
JonC is offline   Reply With Quote
Old 07-19-2015, 03:04 PM   #10
48 coupe
48 coupe's Avatar
HMMMMMMMM I thought it should get up over 200 give or take a few deg. some time . guess not. Look at a tractor or truck oil temp sometime when it's working. It may be 240 or so.
Old 07-19-2015, 04:33 PM   #11
Ronnie
Ronnie's Avatar
I think you may find that that temp is after the oil cooler.
R
Old 07-19-2015, 08:16 PM   #12
Kahuna
Kahuna's Avatar
No oil cooler on my engine
Old 07-23-2015, 11:57 AM   #13
JonC
Ronnie, I don't know about oil cooler but I think it is stabilized oil temp never varies after warm just like the coolant temp. My car is a dry sump Z51 with 10.5 quarts of oil in it.
Old 07-23-2015, 12:22 PM   #14
Oakhurst
Oakhurst's Avatar
I too have also thought that oil temp is very important to proper lubrication. On the 2 cars I own that have oil temp gauges (one is a C-4 ZR1) the oil temp is higher that the coolant when warmed up. Also in the owner's manual on a 300SL called for 12 - 16 quarts of oil
depending on how "sporty" the driving would be. At a "gull Wing Group" meeting it
was discussed that in certain weather conditions, the oil cooler should be partially blocked to raise oil temp. If it is thought oil temp in a flathead is too low, would running a lower oil level raise the temp. Obviously yes, but how much oil is the minimum for proper lubrication.
Oakhurst is offline   Reply With Quote
Old 07-23-2015, 12:39 PM   #15
Bruce Lancaster
From what I've read, higher oil temps typically only occur in engines running at high loads, producing a high percentage of their power capability. In a light car this would be uncommon without trailer pulling, lots of hills, etc.
The only Ford Flatheads I can think of that got a cooler as original equipent were the 1935 Indianapolis engines (from the picture I have seen I think the cooler was in the inlet path to pump!) and engines used in some bren carriers in WWII...
In the carriers, the engine lived deep inside an armored box, and had to work hard because it was pulling around a heavy tracked vehicle. The cooler was in the same sort of hookup that Ford used for full flow oil filters in other applications, and was equipped with a valve system to allow oil to bypass the cooler if it wasn't hot enough to need it. Obviously, this thermostatic control would be desirable, as over cooled oil would be a bad thing.
I've never had an oil temp gauge, but I do know that I've touched the oily end of dipsticks without discomfort when their handles were so hot I need a rag to hold them...
Old 07-23-2015, 04:55 PM   #16
Highboy34
48Coupe has it right. Oil temp will rise only when the engine is under load.
Highboy34 is offline   Reply With Quote
